Main Light Switch
Old Jan 10, 2009 | 10:25 PM
tip49's Avatar
tip49
Main Light Switch
I dont' have a scanner, but if you can visualize the pinouts on my 50 F1 light switch. It has five terminals in total, looking from front, three on left and two on right. If you numbered the left three, back to front: 1, 2, 3 and right ones 4, 5; here is what I meter out. With switch off: terminals 1 and 4 are common. With switch in park light position: 1, 2 and 4 are common, with switch full on: 4 and 2 are common. Confused yet ? 3 and 5 are also common when light sw full on. My manual shows six terminal switch for 51: but here's what I figure: power feeds #5 from ignition switch via starter relay through current circuit breaker. # 3 goes to dimmer switch power terminal. Power from voltage circuit breaker feeds #2. park lights are fed from #1. Instrument lights are fed from #4. How am I doing ?
Tom
Old Jan 10, 2009 | 10:57 PM
bobj49f2's Avatar
bobj49f2
Doesn't your manual have the wiring diagram for the '48-50? If not here it is:
Old Jan 10, 2009 | 11:14 PM
Julies Cool F1's Avatar
Julies Cool F1
Hi Tip,
See if this helps. If you need any other diagrams look in my #1 gallery.
"Hot Bus" is your power source. My lights are powered off a fuse panel (bus) that is hot all the time (ie not switched on with the ingnition switch).
In the light switch diagram, the connection from the Right "R" terminal up and across to post on the left the interior lights rheostat (on the front of the switch that eventually flows from left to right to the instrument lights) is a hard metal shunt connecting those two points.
If you have an earlier type switch that required a separate toggle switch to turn on the instrument lights you will not have the rheostat on the headlight switch, and the hard shunt would be replaced by a wire connecting that "R" post to the separate toggle switch then going on to the actual instrument lights themselves.
The complete lighting diagram is in the gallery as well.
Good Luck,
Julie
Old Jan 11, 2009 | 10:57 AM
tip49's Avatar
tip49
Thanks to Bob and Julie; looks like I was on the right track, I should be able to wire the switch from here. Thanks again.
Tom
jvmcc
May 31, 2016 12:00 PM
eman92082
Apr 9, 2015 01:20 AM
shorthair
Apr 6, 2015 06:59 PM
TRENT310
Oct 26, 2014 02:46 AM
Racerguy
Jul 4, 2011 08:19 AM
