Switch Terminals
Old Apr 8, 2015 | 03:46 PM
eman92082's Avatar
eman92082
Switch Terminals
Is there anyone who can give me a sanity-check on what I think these switch terminals are for? I'm not savvy in schematics and the ones I found are real hard for me to read.
1 - Parking Lights
2 - I'm not sure - There's a "B" partially hidden by the Rheostat Connection. Is this 12V and is it Switched or Constant ?
3 - Would this go to the "Batt" terminal on the Dimmer Switch to power the Lights ?
4 - Tail Lights ? Also connected to the Rheostat to power the Instrument Lights ?
5 - 12V Switched or Constant ?
6 - Gauge Lamps
As always, any corrections or additional info is appreciated.
Dawgie
Old Apr 8, 2015 | 04:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Wrong head lamp switch for a 1949 F1.
FAA-11654-A .. Head Lamp Switch / Obsolete
1950/54 Ford Passenger Cars & 1951/54 Trucks.
Correct head lamp switch for a 1949 F1:
7RA-11654-A .. Head Lamp Switch / Obsolete
1949 Ford Passenger Cars & 1948/50 Trucks.
Old Apr 8, 2015 | 07:18 PM
eman92082's Avatar
eman92082
Yes, understood. Purchased the '51 Switch on purpose so I could control the gauge lights.
Old Apr 8, 2015 | 08:08 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
1 - Parking Lights Correct
2 - I'm not sure - There's a "B" partially hidden by the Rheostat Connection. Is this 12V and is it Switched or Constant ? Constant power from circuit breaker. Should be fused.
3 - Would this go to the "Batt" terminal on the Dimmer Switch to power the Lights ? Correct
4 - Tail Lights ? Also connected to the Rheostat to power the Instrument Lights ? Correct
5 - 12V Switched or Constant ? Constant power from the other circuit breaker. Should be fused.
6 - Gauge Lamps Correct
Dawgie
Answers in red above.
Old Apr 8, 2015 | 09:23 PM
eman92082's Avatar
eman92082
Thank You !
Old Apr 8, 2015 | 10:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't think you want to fuse the headlights or running lights. A circuit breaker will reset after a momentary short, a fuse can't. Losing your headlights can be "exciting" to say the least.
Old Apr 9, 2015 | 01:20 AM
Jolly Roger Joe
IMO any short that would pop the fuse would continually break the breaker after it reset.
Carmanj1
Jan 25, 2016 07:01 AM
duphofff
Sep 6, 2015 05:43 AM
Grizzly93
Large Truck
Jan 19, 2015 02:25 AM
DznyRulz
Mar 11, 2010 11:32 PM
ivanogburn
Jan 5, 2009 02:06 AM
