Ranger fuel caps?
Old Jan 10, 2009 | 07:49 PM
gryc's Avatar
gryc
Ranger fuel caps?
I'm sure this has been discussed but.... I have an 05 and noticed the little trap door inside the filler is missing. Anyone ever seen those things fall out without help of say maybe, a siphon hose? Is it possible for this model to get siphoned? Have you guys had any luck using locking caps also?
Thanks for any suggestions.
Old Jan 10, 2009 | 08:28 PM
drb1956's Avatar
drb1956
I didn't think they were putting the little "trap" door in the fuel filler anymore.. If you buy an aftermarket, make sure that it is the right one for your truck: vented or non-vented..If you put the wrong one on, your check engine light might come on, as your fuel system and EVAP system is monitored by the 'puter..
Old Jan 11, 2009 | 10:54 AM
matt's2.9STX's Avatar
matt's2.9STX
I'd err on vented side to begin with. I think all American Rangers since ~87 should be vented unless I missed something. If you have the original cap, look it over & compare it with replacements. You should have what looks almost like a strainer in the end & other indication of vapor relief. It shouldn't do worse than trip a CEL if it's supposed to be unvented. Also turn it 3 clicks or more after fill-up. I would not want to try a non-vented unless it's well designed for one. THAT spooks me a bit due to common EVAP systems.
Old Jan 11, 2009 | 11:03 AM
matt's2.9STX
Looks like I'm probably behind the times. I saw on AA site an '05 cap for a 4.0L that looks unvented. Must be storing vapor in the evap can like a Toyota until next engine start.
Old Jan 12, 2009 | 08:41 PM
Thoth88's Avatar
Thoth88
Just checked my '06 and it don't got no flap. Bought a STANT locking gas cap and after a couple of months I was getting 'evap leak LARGE code' eery 2-3 days, put stock back on and haven't had a code since.
Old Jan 12, 2009 | 09:07 PM
drb1956's Avatar
drb1956
I think every engine set-up is different- so you can't go by model year-you need engine size, and I think gas tank size might(???) play a factor as well....I would go to the dealer to find out what system(vented/non-vented) that you have, and then you can make an informed decision..
Old Jan 13, 2009 | 07:23 AM
racsan's Avatar
racsan
ive got a locking cap and had no issues, have one on the taurus too. with a full tank the gas might be worth more than the vehicle its in.
Old Jan 13, 2009 | 08:03 AM
wendell borror's Avatar
wendell borror
I didn't know you could still pilpher gas, I've tried to get gas for my tractor from newer vehicles and I couldn't get a hose to go down in there.
Old Jan 13, 2009 | 09:03 AM
matt's2.9STX
I've tried with a '86 Fiero to pull the gummed up crud for hours after I bought it. There is supposed to be a way with small aquarium vinyl hose hooked up to a hand pump, but VERY slow. Not fun. If a thief was desperate, he would be smarter to punch a hole directly in your tank for the siphon. I wouldn't worry about it. Maybe somebody could come up with a way to adapt a hose into a non-vented cap with a strong suction. Until then, forget it.
Old Jan 13, 2009 | 01:13 PM
racsan's Avatar
racsan
ive sipioned fuel from both the taurus and ranger to fill the lawnmower. the tank has to be nearly full though. i use a 3/8 fuel line and boat primer bulb ment for a outboard. have to spray the 3/8 line with wd-40 to get it to slide in far enough. will work though.
Old Jan 13, 2009 | 01:40 PM
99F150's Avatar
99F150
I saw on Motor week that Stant makes a replacement cap that you do not remove when filling like the new factory caps Ford is using.
Can you leave the engine running while filling without setting a code with the new quick fill caps?
michael cook
2009 - 2014 F150
16
Dec 1, 2011 03:13 AM
jimf350
Jul 13, 2009 11:12 PM
neilc88
Feb 13, 2009 09:15 PM
RichardW
22
May 21, 2007 09:33 PM
DOCSpanky
Oct 8, 2005 08:37 PM
