Installed Fumoto
Old Jan 10, 2009 | 06:07 PM
Automator's Avatar
Automator
Installed Fumoto
Changed the oil this morning, on the snow covered drive, and installed the Fumoto valve with the ring. I change oil over 8 times a year and this should really help make it easier.
Old Jan 10, 2009 | 06:33 PM
camodown's Avatar
camodown
nice. Did you need any special adapter or did the regular one work?
Old Jan 10, 2009 | 08:00 PM
Pocket's Avatar
Pocket
It's one of my favorite mods. Sooooooooooooooooooooooooooo easy.
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
8 times a year? That is a lot of driving. I think that should help you with changing the oil. I am thinking about doing the same thing. I don't offroad so I should be good. How many miles do you change your oil?
Old Jan 10, 2009 | 09:06 PM
mybigredford's Avatar
mybigredford
did the fumoto come with a new brass washer or did you have to get a new one?
Old Jan 10, 2009 | 09:19 PM
Steve_250's Avatar
Steve_250
Make sure you get the one with the hose nipple.....
I didn't.
Fantastic device!!!
Old Jan 10, 2009 | 09:30 PM
Tenn01PSD350's Avatar
Tenn01PSD350
What he said. ^^^^^^^^ Man that is a lot of oil changing.
Old Jan 12, 2009 | 09:37 AM
superduty4x4's Avatar
superduty4x4
Comes with a soft gasket installed, no worries.
Old Jan 12, 2009 | 10:06 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I had 13 oil changes the first year I had Nyx. I didn't do it though, since I bought an unlimited lifetime oil change plan from the dealership where I got here. $700 for that plan, but their average time for an oil change is about 1.5hrs!!! I stopped using it since I'm running synthetic now, and they'll only do Rotella 15W40 dino oil. Plus they were just so SLOW!! With the time lost from work, it's cheaper & less frustrating to do it myself, and then I don't give up the keys either. I may need to get a Fumoto soon...
Old Jan 12, 2009 | 10:20 AM
jeff7825's Avatar
jeff7825
I installed a Fumoto on my last oil change, and i'm coming up on needing one again so it will be the first test.
Old Jan 12, 2009 | 11:24 AM
superduty4x4
Get the Fumoto, you'll thank yourself.
Old Jan 12, 2009 | 11:29 AM
john_from_ict's Avatar
john_from_ict
Mine tends to drain quite a bit slower...am I doing something wrong?
Old Jan 12, 2009 | 11:31 AM
mueckster's Avatar
mueckster
I just open the Fumoto valve, punch a hole in the bottom tof the filter, and let'm drain into my 5 gallon drain pan. The used oil doesn't touch my hands. Makes for a 'cleaner' oil change. Everyone should do this.
Old Jan 12, 2009 | 11:37 AM
kccatpower's Avatar
kccatpower
i lifted my truck so i could fit a five gallon bucket under the pan. makes disposing of the old oil easier, put the sealed lid on the bucket when done and take it to work.
Old Jan 12, 2009 | 11:44 AM
mueckster's Avatar
mueckster
Another good reason why a "lift" is needed.
"Hey, honey, I need to put a lift on my truck to make changing the oil easier."
