Rusty oil pan fix.
Old Jan 10, 2009 | 02:00 PM
bkvanbek's Avatar
bkvanbek
Rusty oil pan fix.
I can't afford to replace my very rusty oil pan. Any suggested fixes?
Old Jan 10, 2009 | 02:38 PM
donjamer's Avatar
donjamer
You could smear it with JB weld or maybe some fiberglass..
My son had a leak in an oil pan and used jb weld to repair it.. It took a few coats of the stuff and you need to clean it well for it to stick..
It held but not sure how long.. he sold the POS truck after a while..
Old Jan 10, 2009 | 07:09 PM
MucksUnlimited's Avatar
MucksUnlimited
There is no real good way to repair a leaky oil pan while it's on the truck, the best thing to do is to drain the oil complely out of the pan, even let it drain over night clean the whole area with brake clean than sand/grind the area that was leaking, clean it again than put the jb weld to it, let the JB sit over night before you fill it back up with oil. that could last 3 weeks or 3 years depends on how clean (oil free) you get the area around the whole.
Old Jan 10, 2009 | 07:12 PM
bkvanbek's Avatar
bkvanbek
It is not leaking yet. But it looks thin.
Old Jan 10, 2009 | 10:17 PM
nitrogen's Avatar
nitrogen
wire brush it thoroughly then coat with POR putty, for even better results you can use the putty with fibreglass cloth. it stands for "paint over rust" and its worked great for me as long as there isn't an loose rust flakes
satcom40
Mar 23, 2012 12:12 PM
farmnfly
35
Jun 12, 2011 09:05 AM
bkvanbek
Oct 18, 2008 03:47 PM
getnbz
May 15, 2008 08:20 PM
PAUL_2
Feb 25, 2002 09:31 PM
