Sponsored by: Real Truck
rusty oil pan
Old May 14, 2008 | 09:52 PM
getnbz's Avatar
getnbz
rusty oil pan
i have a 99 PSD and heard of the rusty oil pans on the early PSDs and recomened using JB weld over the rust but it flakes off after awhile is there any other fixes other than pulling the pan thnx
Old May 15, 2008 | 08:52 AM
MikeSDK's Avatar
MikeSDK
If it is not rusted all the way through, get the "starter kit" from POR-15.
Sand the rusted areas to bare metal, and coat with a couple coats of POR-15.
I did mine about a year ago and its holding up great.
By the way, do whatever you can to save it now, because you have to pull the motor to change the pan and get it to reseal properly.
Old May 15, 2008 | 10:02 AM
dkf's Avatar
dkf
Fixing surface rust is super easy. Remove the rust down to clean steel, degrease and paint. Its amazing that people let their oil pans rust trhough when a little paint and some time is all thats needed. Same apllies to diff covers as well.
Old May 15, 2008 | 10:03 AM
Gmeanie's Avatar
Gmeanie
I used por-15 on my rear end cover.
It was rusting pretty bad too.
Old May 15, 2008 | 10:55 AM
firemanpat29's Avatar
firemanpat29
ford fixed this problem for the 6.0s, there is always a coating of oil on the pan to prevent rust!
Old May 15, 2008 | 08:06 PM
getnbz's Avatar
getnbz
i thought that it was from inside out i will have to check into por 15
Old May 15, 2008 | 08:20 PM
99f350sd's Avatar
99f350sd
Try some fluid film or amsoil heavyduty rust preventative spray. Paint will fail over time.
Dick
murdock246
Jun 4, 2013 08:08 PM
satcom40
Mar 23, 2012 12:12 PM
bkvanbek
Jan 10, 2009 10:17 PM
bkvanbek
Oct 18, 2008 03:47 PM
PAUL_2
Feb 25, 2002 09:31 PM
