02 Explorer knocking on cold start
Old Jan 10, 2009 | 11:30 AM
Smurphette's Avatar
Smurphette
Question 02 Explorer knocking on cold start
I have an 02 Explorer that has developed a knocking sound when it is started cold. It has gotten progressively louder; when it started, I would have described it as a ticking noise.
It seems to go away as the engine warms up, and I am not sure whether it is the weather getting colder, or the problem getting worse, but it makes the noise a lot longer than it used to.
I've read the carbon knock thread, and I was unclear if that was a constant thing, or if it went away after a bit like mine.
Any advice is appreciated.
Old Jan 10, 2009 | 07:35 PM
steve(ill)'s Avatar
steve(ill)
put 5 w 20 oil and a new filter and try that.
Old Jan 11, 2009 | 03:31 PM
justin_pistol's Avatar
justin_pistol
sounds like a lifter tapping.....try adding some rislone oil treatment to it.
walmart 5$ quart
or you could get the top end of your engine rebuilt to really fix the problem.
My F-150 tapped really bad 80,000 miles ago but after adding rislone it just taps a bit when first started and then warms up and runs good.
still running stronge @ 180,00
I also run val syn 5 - 20w
Old Jan 14, 2009 | 10:38 PM
Smurphette's Avatar
Smurphette
I'll try that....was planning on an oil change this weekend anyway.
Old Jan 15, 2009 | 02:00 PM
Smurphette's Avatar
Smurphette
W00HOO you guys are awesome - worked like a charm
Poptart
Dec 2, 2012 06:57 PM
trvctyrich
Dec 9, 2011 03:03 PM
Firminator_X
1997 - 2003 F150
Jan 15, 2010 11:44 AM
Cow Hauler
Colorado Chapter
26
Nov 25, 2008 08:01 AM
jcgriffin
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
42
Mar 24, 2004 11:06 PM
