Steering box, need some input regarding leak
Old Jan 10, 2009 | 06:50 AM
tealboy1's Avatar
tealboy1
I talked to a local mechanic who said a moderately bad leak in the seal at the steering box needs to be repaired soon at a cost of $375. In the meantime, i am adding fluid as needed,which he said is fine, but i will need to buy a newly rebuilt steering box, plus labor to properly fix.
any other less expensive and reliable options?
Old Jan 10, 2009 | 07:21 AM
Lazy K's Avatar
Lazy K
If it is leaking from the output shaft new seals can be fitted quite easily and cheaply. In the mean time try adding some Lucas power steering fix. Won`t solve your problem but it should slow the leak.
Do a search here there have been some good threads on the subject.
Old Jan 10, 2009 | 07:31 AM
JRS2's Avatar
JRS2
I went thru this problem as well. I ended up getting a used junkyard replacement. Why ? Because when I took it apart the main shaft lower bearing wouldn't have fixed it because the shaft was pitted. The part itself wasn't that much for my 94, it wasn't that tough of a job ...
Old Jan 10, 2009 | 09:33 AM
deeznuts822's Avatar
deeznuts822
I did the seal replacement on my 88,it was faily easy. The seal kit costs around 20 bucks and can be done in hour or two with i wanna say 1 5/16 socket and a pair of snap ring pliers and a pitman arm puller. Once u remove the nut on pitman arm and pull it u just turn the steeering wheel to full right and the seal pops right out. One thing u must do is clean the groove the snap ring goes in and re assemble. The pitman arm only goes on four ways so u must return steering wheel to position u took the arm off at so u can reinstall
Jkenosh
Oct 13, 2015 08:47 PM
wantahertzdonut
15
Jun 27, 2015 09:58 PM
76ClydeF100
Jun 23, 2014 10:23 PM
Wrecker
Apr 8, 2009 06:46 PM
Jeff Dodson
Feb 25, 2006 03:08 PM
