I have a 1991 F250 4x4. The problem I am having is the steering gear box is leaking. The leak is through the adjuster bolt/nut on the top. I have cleaned it off and can see it come up through the threads. How can I fix this leak. I dont know if there is a O RING under there or not. I had adjusted the steering awhile back and had it to tight and have sense loosened it up so the steering is not to tight, but this leak developed. What do I need to do to fix it
there is a seal in the top and the part # for the kit is (d7az-3e501-b), remove the pit-man arm, two top screws and the plate, there might be another nut on the bottom,snap type rings and it should slide out through the top.
