Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Snow blower elec.starter
Old Jan 10, 2009 | 02:06 AM
mkrog's Avatar
mkrog
I have a snow blower with a 8 horse Tecumseh engine.The problem is the elec starter keeps falling off.Put a new starter on with new bolts and loctite, let it sit for 3days before I used it. Ran about 15 min. and all the bolts on the starter had come loose or fallen out.When I installed the new starter all the bolts were tight,but could it be that the threads in the block are bad.The starter is the 120v type
Old Jan 10, 2009 | 09:55 AM
ckal704's Avatar
ckal704
Sounds like maybe the bolt holes egged out a little bit and inducing that amount of vibration to something as heavy as a starter will work it loose every time, no mattter how much LocTite you put in.
Options as I see them:
1. Epoxy the bolts in. The epoxy will act as a filler and should hold. Of course, it might be difficult to get the bolts out again should you need to replace the starter.
2. Helicoil the bolt holes. They sell thread repair kits for single sizes of bolts relatively inexpensively. Those are probably 5/16 bolts. The thread repair is easy to install: run the oversize tap (included) into the hole, screw in the insert and you are done. I usually LocTite these types of repairs but it probably isn't necessary. You may have to pre-drill before running the oversize tap in, but more often than not, you don't. At least not in aluminum. Here is a link to one of many online sources. Looks like a genuine Heli-Coil kit for 5/16-24NF goe for about $30
Heli Coil Products - ToolSource - 30,000 automotive tools online. Fast Delivery, Friendly service, Secure on-line ordering.
3. Drill and tap for the next largest size bolt. That would be 3/8" 24NF if I am right that the originals are 5/16". I'd go with fine-thread bolts and LocTite them in.
Old Jan 10, 2009 | 02:14 PM
cracked block's Avatar
cracked block
My dads blower is doing the same thing. Starter keeps working loose. Havn't tried locktite, but am leaning that way.
Old Jan 10, 2009 | 09:23 PM
Chaosracing's Avatar
Chaosracing
I would helicoil them first, then if that doesnt work, go to the next size bolt if there is enough metal to do so. I would not epoxy them in place. I had to take apart a mower that someone epoxied the bolts in place with. I was about ready to tell them to scrap it and buy a new one. But with a little heat I was able to get the bolts out and drill and tap for new bolts.
Old Jan 10, 2009 | 10:21 PM
ckal704's Avatar
ckal704
Note: I based my answer on least labor intensive to most.(lazy)
I agree that although epoxy will probably work great, I wouldn't want to be the guy that had to take those bolts out again someday.
I am familiar with that block. There is plenty of aluminum around the original bolt holes to tap to the next largest size.
So it kind of depends on what tools he has available...........
If it were me and I had the 3/8" tap I'd just tap the holes bigger.
But then again, if it gave me an excuse to buy a whole helicoil kit for $150.00 (but hon, I need it to fix the snowblower!!!) I'd do it!
Old Jan 11, 2009 | 03:23 AM
mkrog's Avatar
mkrog
thanks
Thanks guys,went the thread insert route.If that doesn't work I,m trying epoxy.What would be better to use ,epoxt or J-B-weld,I have both.
Old Jan 11, 2009 | 08:34 AM
LSchicago2's Avatar
LSchicago2
If the threads are ok, Drill small holes across the hex of the bolt heads, and safety wire them to each other so they can't turn.
Old Jan 14, 2009 | 12:47 PM
Nitramjr's Avatar
Nitramjr
My snowblower also has the Tecumseh 8 HP motor on it with the electric start. I've owned it for 15 or so years and after about three years I figured out that if I couldn't start it with one or two pulls of the rope, I needed to adjust the carb. I can't even remember when I used the starter last. For me it is easier than running an extension cord to the garage door.
Factola72
24
Apr 7, 2014 06:23 PM
ginch66
Nov 6, 2011 01:41 AM
Explorer220K
Jan 31, 2011 06:36 AM
rplatt7
Aug 18, 2008 11:26 AM
Crumm
31
Nov 21, 2003 10:22 AM
