Sepentine belt question.
Old Jan 9, 2009 | 10:09 PM
Dads79's Avatar
Dads79
Hopefully there is a parts guy on here who can me.I replaced my vacuum pump back in May.Now it's starting to make a little noise like it did before. So I 'm thinking that it wore out way too soon.I've had the truck a little over a year and when I bought it the last owner included new air,fuel,filters and new sepentine belt.I checked the receipt everything matched,so I changed everything with the new parts in Oct.07. New pump was needed in May 08. I decided to check on line to see if my Dayco belt is the right one. Two places I checked online say I need Dayco 5081190,I installed Dayco 5081195. Does any one know what the difference in the numbers are.Belt went right on and seams to have the right tension. I just want to make sure this belt is not causing my pump to fail. Thanks
Old Jan 9, 2009 | 10:16 PM
putz54143's Avatar
putz54143
i think that rebuilt pump is junk seen it befor last only a year or so if should be warranty if not pay the extra for the new one DONT GET THE REMAN
Old Jan 9, 2009 | 10:21 PM
c00nhunterjoe's Avatar
c00nhunterjoe
no clue on the belt, most manufactures have the length differences as the last few digits of the part number. its probably a hair longer or shorter.
Old Jan 9, 2009 | 11:35 PM
BlueMule's Avatar
BlueMule
The belt you put on is 119-5/8 inches and the one you don't have would have been 119 inches.
Old Jan 9, 2009 | 11:47 PM
BlueMule's Avatar
BlueMule
Did you put any grease/oil in the bearing on the back of the pump?
Old Jan 10, 2009 | 08:52 AM
Dads79's Avatar
Dads79
Thank you for the info on the belt. And no I didn't lube anything on the pump. Didn't know I needed to .I just pulled the pump off,and pulled the pulley off and swapped it to the new pump. Then bolted it back on. I didn't see in my manual about lubing anything. What did I miss ? I'm still learning about the 7.3. Thanks
Old Jan 10, 2009 | 09:43 AM
BlueMule's Avatar
BlueMule
There's a set of bearings at each end of the shaft, you cant do anything with the front one but at the rear there is a plug (bolt) that you can remove to add a mix of grease and 90W gear oil.
Old Jan 10, 2009 | 12:54 PM
chas31310's Avatar
chas31310
The belts are not that expensive; I'd suggest you get the correct belt and keep the other as a spare. The tension system accomodates some stretching of new belts but you've likely used up that with the longer belt. I wouldn't risk slippage when you can correct it without much cost or labor. CJ
Old Jan 10, 2009 | 02:17 PM
KevinC.'s Avatar
KevinC.
I checked the other day at advance auto for a belt and they wanted 68.00. is that the going price?
Old Jan 10, 2009 | 10:25 PM
crzycrazycarl's Avatar
crzycrazycarl
i paid 38 at advance like one month ago
WhozeYoDaddy
Jul 6, 2015 10:31 AM
sand_fiend
30
Apr 16, 2012 07:54 AM
WildTurkeycj8
Aug 22, 2011 02:04 PM
Alpine6
18
Mar 11, 2008 04:33 AM
Cyberbug
Dec 21, 2005 10:01 AM
