Sponsored by: Real Truck
Hello, I need quick help with susp height
Old Jan 8, 2009 | 08:49 PM
gmm's Avatar
gmm
I am new here, but not to working on trucks. In fact I work on some of the biggest trucks in the world. 13' tall tires, like a 2000 sq ft house with an engine.
I have a 2002 f250 superduty 4x4 with a 7.3 and need to know what the measurement from the top of the front axle to frame. If anyone has a factory hieght truck and can help me I would appreciate it.
Thank you
Old Jan 8, 2009 | 09:16 PM
fxstbchopper's Avatar
fxstbchopper
Welcome to the FTE!
I have a 2.5" leveling kit on my truck so I am no help but I just wanted to welcome you this is a great forum since you have a 7.3 check out that section of the forums.
Old Jan 8, 2009 | 09:29 PM
gmm's Avatar
gmm
I really just need a round about, I can get pretty close from that measurement, if you wouldnt mind checking for me. I would really appreciate it.
Thank you
Old Jan 8, 2009 | 09:34 PM
fxstbchopper
I got 10" from the top of the front axle to the bottom of the frame. That is at the up bend where the axle sits under.
Old Jan 8, 2009 | 09:46 PM
gmm's Avatar
gmm
Thank you very much, that is exactly what I needed to know.
Old Jan 8, 2009 | 09:49 PM
fxstbchopper
Hey no problem you will find a lot of helpful people on this forum. I am mostly in the 7.3 section and there are a lot of knowledgeable people over there.
And again Welcome to the FTE.
Edit: here is a link to it https://www.ford-trucks.com/forums/forum31/
Old Jan 8, 2009 | 10:25 PM
DCSpecial's Avatar
DCSpecial
Stock crew cab SWB 7.3 is generally 7.5" +/- 0.5" from the top of the axle tube (next to the spring perch) to the bottom of the frame rail (by the bumpstop) of the front axle.
gottahaveaford
1978 - 1996 Big Bronco
Feb 9, 2015 10:25 AM
TobiasR.
Dec 4, 2011 04:08 PM
usmctadpole
Jan 25, 2011 10:11 PM
chrissn95
1997 - 2003 F150
Dec 5, 2010 04:51 PM
351Lightning
Oct 29, 2004 07:05 PM
