4X4 --> ESOF
Old Dec 4, 2011 | 12:17 PM
TobiasR.'s Avatar
TobiasR.
4X4 --> ESOF
hi everyone
today I need help with the 4x4 on my truck.
How can I check out if he had "shift on fly" or not ?
or can every truck with 4x4 "shift on fly" ?
How works "shift on fly" (how many mph) ?
my truck is a 1999 F250 SD 4x4
thanks
Old Dec 4, 2011 | 12:26 PM
twags6's Avatar
twags6
Trucks with ESOF have the **** on the dash and typically "auto" written on the hubs instead of "lock". You can shift into 4hi at speeds up to 45ish IIRC. Trucks that have a shifter on the floor can only shift on the fly when both hubs are in the locked position, and in theory, can be put in 4hi at any speed.
Old Dec 4, 2011 | 02:18 PM
TobiasR.'s Avatar
TobiasR.
hi thanks...
I have the **** on the Dash, but I've locked my hubs because the vacuum hoses have a leakage. And that says that I can shift in 4Hi at speeds up to 45 mph ?
That's great I thought I can only shift in 4Hi if the Transmission is in neutral ...
thanks
Old Dec 4, 2011 | 02:24 PM
MisterCMK's Avatar
MisterCMK
You can only shift into 4Lo if the truck is in neutral.
If you have your hubs locked already you can shift into 4Hi at any speed.
Old Dec 4, 2011 | 03:10 PM
TobiasR.'s Avatar
TobiasR.
that's a new impression
I drive the car since 2 years but I don't know that
Thanks a lot
Old Dec 4, 2011 | 04:01 PM
MisterCMK's Avatar
MisterCMK
If the hubs are not already locked in and you engage them the front axle must be brought up to the speed of the vehicle. Does that make sense to you?
Old Dec 4, 2011 | 04:08 PM
TobiasR.'s Avatar
TobiasR.
yes, it make sense
thanks
IHpuller450
Apr 6, 2017 07:56 PM
foothills321
15
Nov 11, 2014 11:38 AM
dougbrown
48
Feb 12, 2010 02:00 PM
Kep4
Car/truck Buying Advice
Mar 3, 2005 08:10 PM
wolfie64
Bronco II
Feb 21, 2005 02:11 PM
