Sponsored by: Auxito
02 f150 engine swap need help.
Old Dec 3, 2010 | 05:33 PM
chrissn95's Avatar
chrissn95
Hi my name is chris. I have a 02 f150 4x4 xlt with the 5.4 in it. I picked up a 02 lighting motor up for cheap I am wanting to put it my truck and i wasnt sure it if it would work. if it does work what parts will i need to put it in my truck.
Old Dec 4, 2010 | 05:23 AM
phil6608's Avatar
phil6608
Yes it will most definitely work!
First thing you need to do is beef up your tranny!
Then , depending on what all came with the motor , you will need most of this list.
http://www.madenterprise.com/catalog/scparts.htm
Then you will need a good custom tune for your computer to make it run.
Old Dec 4, 2010 | 03:32 PM
chrissn95's Avatar
chrissn95
its a complete motor with the computer also. thanks for the help.
Old Dec 4, 2010 | 04:59 PM
phil6608's Avatar
phil6608
You wont be able to use the Lightning computer.
You need to use your stock computer and have it tuned to run the L motor.
Old Dec 5, 2010 | 12:08 AM
chrissn95's Avatar
chrissn95
o i didnt know that.what about the wiring harness
Old Dec 5, 2010 | 01:55 AM
phil6608's Avatar
phil6608
They say you can use your stock wire-harness ,but I think you have to splice in 1 or 2 wires.
Not sure how because I used a Lightning engine wire-harness.
Old Dec 5, 2010 | 04:10 PM
chrissn95's Avatar
chrissn95
yea i will just use the lighting harness. wat about the ac pump and radiator
Old Dec 5, 2010 | 04:51 PM
phil6608's Avatar
phil6608
You can just use your stock ac and rad.
I did without a problem.
02ranch250
Computer Chips & Tuners
15
Apr 25, 2014 07:55 AM
4x2ford302
Exhaust Systems
Jun 15, 2013 03:42 PM
danskool
1997 - 2003 F150
Nov 28, 2012 11:30 AM
