glow plugs
Old Jan 8, 2009 | 05:30 PM
HTi-Enright's Avatar
HTi-Enright
glow plugs
about how long will it take to change out the glow plugs on my 99' f-350??? just curious to know what i am getting myself into
Old Jan 8, 2009 | 05:39 PM
Pocket's Avatar
Pocket
Depends on your wrenching abilities. Plan on a few hours if you've never done it before. Passenger's side is a bit tougher than the driver's side.
Old Jan 8, 2009 | 06:06 PM
superduty4x4's Avatar
superduty4x4
What Curtis said. I was a virgin when I did mine this summer, took a couple hours. Changing the GP's out is the easy part, the biotch of the job is getting to all the valve cover bolts- extensions and wobble joints are your friend!
Old Jan 8, 2009 | 06:36 PM
camodown's Avatar
camodown
Check your UVCH carefully. I ended up breaking mine. Also, be VERY careful with the zip ties on the harness. I broke most of mine and they disappeared into the dark abyss haha. Took my over 5 hrs because i had to go to the international dealer at 10:30 pm for new UVCH harnesses. Use a samll tube to suck the oil around the gps out too. Don't want oil draining back into the heads
chombine
Oct 18, 2006 07:04 PM
backhoeken
Aug 25, 2006 05:34 AM
Coolbreeze
Oct 10, 2003 12:18 AM
alanscott
Aug 12, 2002 02:26 PM
cyberbyrd
Feb 3, 2002 04:42 PM
