Relpacing Glow Plugs
Old 10-09-2002, 09:06 AM
Coolbreeze
Coolbreeze is offline
Coolbreeze is starting off with a positive reputation.
Old 10-10-2002, 11:07 AM
Johncos
Johncos is offline
Johncos is starting off with a positive reputation.
Hi All,
I actually have a couple of questions. First, how do I replace the glow plugs on my 96 7.3 PSD? Do I need to remove the gas filter cover and valvue covers? Where are the glow plugs located? Are they under the valve cover?
Second, Where is the best place to buy replacement plugs? I remember someone mentioning a Navistar dealar online, but I can not find the link.
Thanks for all of your help!
Old 10-10-2002, 11:27 AM
The Diesel Dude
The Diesel Dude is offline
The Diesel Dude is starting off with a positive reputation.
The glow plugs are under the valve covers. If you use a quarter in drive wobble extension and a short deepwell socket you can get them out without removing the rocker arms. Torque the glow plugs to 168 inch pounds and the rocker arms to 25 foot pounds.
Old 10-10-2002, 02:21 PM
Johncos
Johncos is offline
Thanks for the info. Is 168 inch pounds equivlent to 14 ft pounds?
Old 10-10-2002, 11:45 PM
The Diesel Dude
Yes, 14 ft.lb.
Old 10-03-2003, 01:08 PM
FatDutchMn
FatDutchMn is offline
FatDutchMn is starting off with a positive reputation.
What is the practical and advantageous mileage to replace glow plugs?
Old 10-03-2003, 11:24 PM
basstardo's Avatar
basstardo
basstardo is offline
basstardo is starting off with a positive reputation.
The only reason to replace glow plugs is if they are bad. Sometimes the tips can break off or they burn out, which makes it a PITA to start in the winter time. I think I have a couple bad plugs myself, but I have no desire to tear into this engine in my driveway, especially since this is my only ride. I'm gonna test the relay and the plugs (if I can) and if I find any problem I'm gonna let the dealer do it under the engine warranty. I figure 100 bucks for new plugs isn't that bad.
Terry
Old 10-10-2003, 12:18 AM
91 F-350 Crewcab P$D
91 F-350 Crewcab P$D is offline
91 F-350 Crewcab P$D is starting off with a positive reputation.
Changing glow plugs are a piece of cake took about 90min
in my truck had to remove the filter cover,turbo inlet pipes and dip-stick bracket left side rocker cover comes off easy enough,
but the right side is a bear i was able to just slide it down enough to get to the plugs all i did to get them out is break them loose and twist them out with a piece of vacume hose and screw
them back in with the hose till it bottoms and torqe to 168in#
make sure you wipe the rocker covers and seals down real good or they will seep good luck not a bad job to do at home
good luck
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Relpacing Glow Plugs
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
