I have been thinking pretty hard about the 6637 mod, and was just checking out the custom fab air box instruction on F350-6's link in his sig line. How much real difference will the 6637 mod make if I don't chip or exaust it?
I don't think I have cat to delete. I thought that was true on all 2000's or is mine different?
mine was a cali, so i had a cat, but i dunno bout them double-oh's. if you dont have one, then get a muff delete. i found tough that the highest HP and whistle gain came from the cat, not the muff.
the 6637 moves more air. thats the only difference. you will be able to actually hear the turbo now and gain maybe 3-4HP and .5MPG after you stop flooring it to hear the turbo.
good thing i didnt say i know!
PS. megawatt, can i be added to the RHN evem if i dont have a NBS seventhree and am no at 400?
We all learn from each other my friend!
When you become a supporter or your post count hits 400 You can get in we do have a couple of OBS guys. Send me an email at jsouza@roadsidehelpnetwork.info and I'll fill you in on the details.
After looking up a part for me, one of my local AutoZoo employees told me about a sale they were having and said I should take advantage of this great sale and change my spark plugs and wires.
Dang Chris, you should have had him look all day for the proper plugs! LOL!!!
After cleaning my battery terminals and adding Noelox on the terminals, my batteries lasted from the inital post (1/8/09) to just a couple of weeks ago (9/23/09). I got another eight months (and a burning AZ summer) out of batteries I thought were ready for the recycle box.
I did a little write for this very occasion. I am retired from the Telecom industry, part of my job was to insure that our standby gensets would start on come on line every time we had a power failure. It that instant the start battery became the most important component in the entire power system.
So here goes.
PHP Code:
Basic annual PSD start battery maintenance 101.
WARNING!!!!!
The batteries in our trucks have enough power to weld wrenches and throw some serious sparks all over the place!
Observe batteries for corrosion, dampness or water spray. The fluid on top of the battery is an indicator of overcharging or shorted cell. Look at the cables and check for corroded connectors or cables. Once the cables get corroded, its time to replace them.
Remove batteries:
Remove the ground (-) cables on both batteries to safely kill power to truck. Remove the positive (+) cables from both batteries. Remove the hold down clamps on both batteries. Remove both batteries from the truck. On the vans, the second battery is under the side cargo door, mounted on the frame rail in a metal battery box. The battery cables need to be disconnected from the frame rail to get enough slack to allow the battery box to be lowered. The box must be lowered to access the battery inside. I use a small jack to cradle the box and lower it after removing the bolts in the frame. Once the box is lowered the plastic lid needs to be removed to gain access to the battery inside.
Clean batteries:
I spray the batteries down with a degreaser and then hose down with a garden hose. I also use a degreaser on the battery box and battery shelf followed with water from the hose.
Fill batteries:
Take a flat blade screwdriver and remove the caps of the top of the cells. The fluid level should be between the vertical plate inside and the lowest level of the ring inside the cell. Bring the level of the acid up using distilled water, a commercial battery filler is the best tool for this purpose. It automatically shuts the flow of water when it gets to the right level.
Clean terminals:
I clean the battery posts and terminals with a round brush battery tool used for that purpose, and a shot of brake cleaner makes sure you get down to shiny metal on both surfaces. A wire brush on the connectors will help to remove any corrosion.
Test Batteries:
I use a commercial load tester to do a load test on each battery. The first part of the test measures the open circuit voltage. They should be somewhere between 12.2 and 12.6VDC. A reading of 2 volts less than the open circuit test indicate a shorted cell. DO NOT test the battery if you suspect a shorted cell, it may EXPLODE! The second part of the test places a load across the battery to test the condition of the battery. If you don’t have access to a load tester, you can and should take them to be tested. If either battery is weak, replace both of the batteries. Get the largest CCA battery that fit into your truck.
Examine starter cables:
This is the perfect time to do a complete exam of the cable at the starter. Due to high current and many heat cycles the connection needs to be absolutely perfect. I would recommend that the connection be removed cleaned to a shiny surface and re-installed. Make sure that you do a careful inspection of the ground side cables. They should be clean and tight. Now is the time to remove the connection and clean to make sure the connection is in good shape.
Reinstall batteries:
Once all the cleaning and prepping is done re-install the batteries and clamps.
This is the part that will raise an eyebrow or two. I use a marine grade of bearing grease to seal the connections inside and out. Coat the post and connector with a light film where the lead is exposed. When the connecter is tightened onto the post the grease will squeeze out and seal the connection from the inside. Lead is very porous and will allow acid to creep up the posts from the inside causing corrosion. Be careful when tightening the bolts on the connector, this is an electrical connection NOT a mechanical connection. If the connection is too tight the lead will flow and become loose with heat cycles.
Take good care of your batteries and you will get longer life and a more dependable truck.
Nick 99
Noalox is the trade mark name by Ideal. It's primary use is to inhibit corrosion when terminating aluminum wires or copper to aluminum connections (via a lug) I have used di-electric grease before and Noalox is far more corrosion resistant. Plus it is very highly conductive.
I'm about to head out the door and hit my local HD/Lowe's, but here's my question:
Obviously, it's best to have freshly cleaned posts & clamps for this connection, but do you:
1) coat the post & clamp surfaces first, including the contact areas, OR
2) reconnect & tighten, and then apply a coating over as a sealant?
Option 1 seems more thorough and since Noalox is highly conductive, the better route, but given your electrical expertise, I thought I'd ask.
Has anyone else used a product called Whip to coat the battery terminals? It is a black coating that gets firm after application and does seem to prevent corrosion. I've used it for a few years and have had very good results with it. I had used anti-seize compound before but this stuff is cleaner. The Noalox sounds like a good product to put on the terminal before putting on the cable clamp and then use the Whip on top to seal the connection. Or does Noalox firm up after application?
I prefer to clean the posts and terminals to shiny metal inside and out, then coat all surfaces inside and out with blue marine grease and then reconnect terminals to the posts. The excess gets squeezed out and seals out any oxidation.
great advice. I own a 08 ranger and for the life of me, I can't take the terminals off the dam battery. They loosen and turn but they don't come off. It seems ford must have some kind of tool to take them off, that way you have to bring the truck to them. Help!!
Wrong forum, but I had a 2000 Ranger before this truck, and I hand no problems getting them off. Aren't they the screw-in type instead of the clamp type?
At a local truck parts supply house, I ran across a battery post protectant from PB Blaster. I figured PB is good chit, so I tried it. Worked great on our class 8 trucks.
