Sponsored by: Real Truck
Loose shift lever
Old Jan 16, 2010 | 08:40 PM
bterry's Avatar
bterry
http://www.silverstatefordparts.com/.../M/ME99630.gif
I need part 6, tube. 29 bucks at SilverState. The shift lever goes into this part, and is held in with a pin. The hole for the pin is worn, as well as the cavity that the shift lever goes into. What is not shown in the picture, is the hole in the end of the lever (and tube), and the little pin that holds the lever in.
Old Jan 16, 2010 | 09:49 PM
57fomoco's Avatar
57fomoco
[quote=bterry;8377950]http://www.silverstatefordparts.com/.../M/ME99630.gif
I have found that most of the time when the outer tube (#6) is bent or broken that the inner tube (#11) is also twisted. I always change both (#6 and # 11) at the same time. also I always change out the bushings (#8) in your picture at the same time. The parts are cheap and are usually available at the local dealership. I usually put a little light grease under the bushings for a little extra insurance.
Old Aug 19, 2010 | 11:31 PM
edub32's Avatar
edub32
Does anyone have a picture of this bracket on the steering column where these nuts need tightened? Also is removal of the ignition necessary or just the steering column shroud?
Old Oct 25, 2010 | 03:19 PM
bohiaa's Avatar
bohiaa
Revisited this thread...
I am needing to do this. But have had NO experance with removing the the steering wheel. and key switch. I'm afraid of the air bag. can some one who has done this please guide me through it...........?
or better yet come do it for me... :-)
Old Oct 25, 2010 | 03:27 PM
bohiaa's Avatar
bohiaa
Sorry All: I mis read the post you dont have to remove the steering wheel.
Pls forgive me I had to take a CrAzY Pill a while ago.... guess there not working anymore
Old Nov 7, 2010 | 11:27 PM
pwhite144's Avatar
pwhite144
I love this website. I had the same problem, a suddenly loose shift lever. After looking it up here, I went out to the Excursion and the culprit screw lay in the grooves of my floor mat. I was able to put it back in as well as tighten the other screw just by removing the cosmetic "fuze panel" or lower instrument panel cover. Thanks for the help!!
Old Jan 9, 2011 | 04:04 PM
Coastie6's Avatar
Coastie6
Check out this post; forum member badlar has an image that would be helpful in determining if your shifting problem is due to the loose torx screws.
https://www.ford-trucks.com/forums/1...ml#post9799019
Old Jan 9, 2011 | 04:47 PM
Jarvis250's Avatar
Jarvis250
my trucks shifter is also very loose. My shifter works perfectly and shifts tightly, but the actual shift lever is very loose, it moves up and down loosly (about 2 inches) in all gears. Is this the problem that is fixed by these torx screws? By reading this thread it sounds like it is shifting through the gears loosly and not the actual shifting lever that is loose. Thanks for any insight
Old Jan 13, 2011 | 02:47 PM
pwhite144's Avatar
pwhite144
Jarvis250,
It sounds like the problem mine was having. The torx screws are very easy to get to. Take the fuse panel off and get on your back in the floor board so you can look up into the cavity with a light. This thread gives a very good picture of where they are: https://www.ford-trucks.com/forums/1...g-problem.html
I hope you get it fixed!
Old Jan 16, 2011 | 04:12 PM
Jarvis250's Avatar
Jarvis250
Thanks pwhite144, I will have to look into this sometime this week.
Old Jan 18, 2011 | 12:31 PM
Turx's Avatar
Turx
Sorry to bring up an old post, but in a "search" this is all that came up. My problem is at the very end of the shift lever, where you would hold it to change gears, the O/D lock-out button is in this part. 92 F350 4x4, 7.5, E4OD.
Old Jan 18, 2011 | 06:36 PM
Jarvis250's Avatar
Jarvis250
tried tightening these torx screws, they were already tight. I am thinking it is some kind of bushing in the actual lever, any ideas?
Old Jan 18, 2011 | 08:51 PM
  #28
2002 F350V10's Avatar
2002 F350V10
I was quite cautious first time I removed an air bag, however its a piece of cake. Simply disconnect the battery and wait a half hour. 2 covers on the back side of the steering wheel , and 2 small bolts under neath. After that , lift the air bag out, and unplug 2 connectors. For the wheel, loosen a torx bolt in the center, and use a 2 jaw gear puller to pull the wheel loose, and then remove the torx bolt.
If you loosen the column and drop it down a little, on the top of the column are 2 u shaped clamps with bolts for the shift lever under the dash area.
Old Jan 20, 2011 | 06:24 PM
  #29
rob1994AerostarAWD's Avatar
rob1994AerostarAWD
I had the same problem on my 2000 F250. The shifter was loose and on one occasion it wouldn't start in park until I wiggled the shifter. When I checked a few minutes ago, both Torx screws on the bracket were loose. I just went out and tightened them up under the dash. I didn't have to remove any covers or shrouds. Five minute job. The photo on this thread was helpful.
Old Jan 29, 2011 | 07:32 PM
  #30
whiteywhip's Avatar
whiteywhip
ran into the same problems....went to ford and picked up the plastic bushings....one pkg of 2 pieces part #F3TZ-7L278-A and also bought ... two clamps part# F2DZ-7E400-A.....figured out how to remove the lock and it was a piece of cake......its better but not perfect
