Speedometer sending unit
What is the best way to convert a mechanical system as mentioned above to an electric system. There is a good article on Electronic Speedometers in this months (NOV 2002) issue of Classic Trucks . They go into detail about the different sending units for electronic speedometers. They listed the following - Signal generators or Hall Effect Generators/Switches, Vehicle Speed Sensor VSS, Magnetic Proximity Sensor, Signal Converters.
Has anybody done a mechanical to electrical conversion for the speedometer. If so what type of sending unit did you use and how did it connect to the tranny. What problems came up and how were they resolved.
Responses appreciated
I have a '69 F250 with a C6
Rob
Robert
72 F-100 Ranger XLT W/ 86 5.0l W/ AOD
krazdndenver(No Email Addresses In Posts!)
I only have three minor comments. One might be helpful.
First, why do you want to do this? Is it to get cruise
control? Were you thinking of using a new speedo, or
using your old one? I'm merely curious. It seems that
some new Fords still use plastic gears to drive the
speedo cable. The Tremec TKO in my Torino is the same
trans used in the Mustang Cobra R's, and my TKO uses
two plastic gears and a cable (it's actually the exact
same plastic gears as in the old 1965 Toploader 4 speed,
and the T19 I just pulled out of my 1972 F100). You might
see how the Cobra R's speedo is driven (i.e., is it a cable
from the trans, or do the gears drive a generator, which sends
an electrical pulse to an electronic speedo? I honestly
don't know...just thinking out loud).
My second comment might be helpful. As I understand it
the speedo (but not the odometer) in our trucks uses a
spinning magnet (seperated from the speedo needle by an
air-gap) to "pull" the speedo gear "up." As the magnet
spins faster, its magnetic pull gets stronger, and hence
the speedo needle rises. Simply, the speedo needle is not
gear driven. My understanding of how this works comes
from the old, FTE truck list. You could search the archive
for the original discussion...I think I remembered it
correctly.
Finally, you might consult with a local speedometer shop. When I
lived in Cincinnati there was a shop downtown called
"Cincinnati speedometer." I once talked to them about fixing
a speedo problem. Perhaps there is a similar place near you
with knowledgable people.
Hope this helps. Let us know how this goes and what you
find out.
Ohio Bill
