Main E- Brake cable Removal
Old Jan 7, 2009 | 02:34 PM
gliderdad's Avatar
gliderdad
I have been working on a 66 body swap to a 72 frame.
In getting the frame stripped, I found the ebrake cable to be extremely irritating to remove where it clips to the frame under the bed.
I finally got a regular hose clamp and tightened it around the fingers that retain the cable to the frame, but loose enough so that the cable would slide through the frame hole while pushing the clamp back off..it worked great!!
Kind of smiliar to a piston ring compressor tool..
Hope this helps all you other cable puller folks..!
Old Jan 7, 2009 | 10:17 PM
garbz2's Avatar
garbz2
Exactly the way i remove all E brake cables...Works on the backing plates also.
Works every time.
Garbz
wfilkins47
May 15, 2014 09:16 PM
kjvforme
16
Sep 17, 2013 07:44 PM
ddowell1
May 25, 2013 07:07 PM
blueeyedfordguy
Electrical Systems/Wiring
16
Apr 19, 2010 10:42 AM
totalrecall
Feb 9, 2009 05:30 PM
