Sponsored by: Real Truck
Brighter Reverse Lights
Old Jan 9, 2009 | 11:27 PM
  #31
enduro4231's Avatar
enduro4231
I made an insert that goes inside my receiver hitch. Used a ~14" piece of 2" box tubing drilled a hole in it for the hitch pin, then welded a short length of 1" flat bar on the bottom with (2) 3/8" holes in it for the lights. Capped the end. I used 2 4 or 5" utility lights. I then grounded the lights to the insert itself which is grounded to the truck thru the receiver. I wired them to the reverse circuit with a quick disconnect plug so I can pull it out easily.
Works awesome and can be removed/installed in about 2 seconds.
Old Jan 9, 2009 | 11:54 PM
  #32
Saleenguy's Avatar
Saleenguy
Originally Posted by RACERX7775
heres mine that i have on my excursion. i cant mount them on the top of the hitch like the super dutiescan because there is no gap.
edit: NO COMMENTS on the munchkin in the backround squating. Its me and i'm 6'5" 250. Although, i look like i'm 2'5" and 400 lbs. lol.
Hey, who is the short, chubby guy in the reflection there?
LOL
Sorry i am weak and could not resist.
Old Jan 10, 2009 | 08:49 AM
  #33
BlackJeep's Avatar
BlackJeep
It makes you wonder. Since everyone seems to have the same issue (poor illumination from the factory backup lights) why the manufacturers don't do something about it? Or at least offer better lights as an option..
Old Jan 10, 2009 | 11:26 AM
  #34
SpringerPop's Avatar
SpringerPop
It appears to me that there is an error in the relay wiring diagram above.
The wire that goes off to ground from the switch shouldn't be there.
As it is wired, the switch flipped one way will turn on the aux back-up lights.
Flipped the other way, it just blows the fuse.
Of course, if that's the intent, then go for......
Pop
Old Jan 10, 2009 | 11:32 AM
  #35
dchamberlain's Avatar
dchamberlain
Pop
If that's a double throw switch, then you're right. I'd hazard a guess that it's a lighted switch, and the purpose of the ground is to provide for the light?
Old Jan 10, 2009 | 12:30 PM
  #36
SpringerPop
Shouldn't that then that should be spelled-out to avoid confusion and drawn differently, or spelled-out in a parts list?
I know, picky, picky, picky!
But there's no need for ambiguity when we can avoid it.
Pop
Old Jan 19, 2009 | 06:20 PM
  #37
08power2spare's Avatar
08power2spare
GregsSD,
How did you get the panel belowl the steering columb off to gain access to the upfitter pigtails? Also are there pass through wires in the harness to the under hood area?
Thanks for any help
Old Jan 19, 2009 | 07:00 PM
  #38
jasfaa's Avatar
jasfaa
The panel just pops off.
Old Jan 20, 2009 | 12:47 AM
  #39
GregsSD's Avatar
GregsSD
Originally Posted by 08power2spare
GregsSD,
Thanks for any help
Take the cover off to gain access to your fusepanel, then unbolt the fusepanel (4 small bolts) and it will pull away from the dash just enough to give you access behind it.
Yes there are 4 pass-thru wires also just behind the fusepanel.
Old Jan 20, 2009 | 07:34 AM
  #40
caprang's Avatar
caprang
If you have a 2008-09 you dont have to drop the fuse panel. The wires are located just above the E-brake pedal.
Old Jan 20, 2009 | 10:35 AM
  #41
08power2spare
Thanks to all for the helpful info. As soon as it warms up a bit, I will get started.
Old Jan 23, 2009 | 09:44 PM
  #42
08power2spare
Thanks to all for the help. This site is great with the help that members contributite. I installed the factory replacement fog lights without removing the bumper. I bought them for about $60 delivered. All upfitter wires and the pass through wires through the firewall were easy to access too. I've got the sealed beam headlamps and changed them to Silverstars and with the fog lights, Wow what lights I have now.
Old Jan 23, 2009 | 11:38 PM
  #43
BMWM1's Avatar
BMWM1
Here is a picture of mine.
Old Jan 24, 2009 | 01:18 AM
  #44
bayou barataria's Avatar
bayou barataria
If you like a lot of light northern tool has a set that take 2 h-4 bulbs each, you can replace them with up to 150 watt bulbs. I ordered a set and they came in today, they have glass lenses and look pretty good, I,ll hook 'em up tommorow and see how they work. They cost less than 20 dollars.
Old Jun 9, 2009 | 01:25 AM
  #45
BMWM1's Avatar
BMWM1
Here is a pic of my hid reverse lights
MichaelKnight
1983 - 2012 Ranger & B-Series
Apr 28, 2016 03:25 PM
OLDBLUEF250
Feb 17, 2016 06:12 AM
ALR1955
Mar 26, 2015 05:00 PM
2006LJ
Jan 16, 2014 10:01 AM
GQROD
Jan 3, 2010 11:26 PM
