Installing telescopic mirrors
Old Jan 6, 2009 | 02:31 PM
dunerunner25's Avatar
dunerunner25
I think its time for my tow beast to get some new mirrors so I can see my trailer when I am backing up. I want to do the install myself. I would like to do somthing simi simple but also have the mirrors be fully automatic ajustable( telescoping and mirror ajustment)
My X has the stock mirrors with the red arrow turn signal in them…how hard is it to install telescopic mirrors for towing? How do I start to take them apart? Will I be able to set them up for adjustment from inside the X off the stock toggle switch? Any brands I should really look at, OEM, Aftermarket?? Any info will help.
Old Jan 6, 2009 | 02:47 PM
wiingnut's Avatar
wiingnut
There are some instructions for a mirror swap in the Super Duty Tech Folder. You'll find them about 2/3 down the page. See if they will help.
Old Jan 6, 2009 | 06:50 PM
WJC's Avatar
WJC
I Bought Aftermarket Mirrors From Koolvue Mirrors. They Look Oem, However, Cost Half. Make Sure They Send You The Wiring Connector When Ordering. Extremely Easy To Bolt On, Actually A Direct Bolt On. All You Have To Do Is Remove The Door Panel So You Can Disconnect The Factory Mirror Connector And Remove The Black Factory Trim Piece On The Door By The "a" Post. Shouldn't Take More Than A Half Hour.
Old Jan 6, 2009 | 07:28 PM
1 Excursion camper's Avatar
1 Excursion camper
What year is your X? I just replaced my stock towing mirrors with the newer "factory chrome/lighted" tow mirrors. for me it was a direct bolt and plug in. the only wire I had to run was for the running light.
Old Jan 7, 2009 | 10:21 AM
dunerunner25
Its an 05 Limited X V10. Thanks guys for all the great info.
Old Jan 7, 2009 | 11:01 AM
1 Excursion camper
You will probably have the running light wire already in the connector! should be a direct plug in!
Old Jan 7, 2009 | 11:22 AM
nordy racer's Avatar
nordy racer
what about the adjustment part? is it auto from inside the cabin or do you have to do it by hand?
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by dunerunner25
but also have the mirrors be fully automatic adjustable( telescoping and mirror adjustment)
If you want automatic or powered telescoping feature you have to go with 08 mirrors. You'll also have to wire a switch to power the telescoping feature.
Otherwise, the telescoping feature is manual.
I highly suggest the 08 mirrors anyway. They are far superior to the 99-07 towing mirrors. I removed my towing mirrors and replaced with 08's with marker & signal but manual fold & telescope.
ih2150red
Aug 27, 2011 11:55 PM
d60d70
Modular V10 (6.8l)
18
Aug 13, 2007 09:40 AM
Technocrsr
Feb 17, 2007 09:13 AM
Fishallot
1978 - 1996 Big Bronco
Nov 22, 2005 05:52 PM
gundamford54
1997 - 2003 F150
13
Jul 22, 2004 10:46 PM
