Need ECM, which one?
Old Jan 6, 2009 | 12:26 PM
aldridgec's Avatar
aldridgec
Looks like I need a new ECM. I have VDH4, should i bother trying to find any other programs? VDH5? I'm getting a used one because A) It's cheaper, B) Ford is backordered, C) I don't want to get it programmed.
Anyone have suggestions on the code?
Old Jan 6, 2009 | 12:39 PM
superduty4x4's Avatar
superduty4x4
PMT1 or PMT2 are probably the most preferred, not sure if those were offered in 02-03 though... Any PCM you find should be plug and play, no programming required. Just make sure to get one from an 02-03 as the pinout on the connector changed.
Old Jan 6, 2009 | 12:57 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Unfortunately, you're stuck with what was offered in 02/03. However, there are a few tuners out there that can hook you up with shift characteristics of the PMT1 PCM in your DPC-462 PCM.
Oh, the reason an older PCM won't work is because of the communication bus used in the 02/03 trucks that the earlier ones didn't use (to keep it simple).
Old Jan 6, 2009 | 01:19 PM
aldridgec's Avatar
aldridgec
I have no problems with what I had, just wasn't sure if since I had to spend the money if the few newer ones were any better worth getting. Truck runs (ran?) great.
Old Jan 6, 2009 | 01:21 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Nah. If you don't have a chip, then yes, you may notice a little bit different shifting strategy with a different series of PCM (VDH4 vs. VDH5). I don't know the exact differences off the top of my head for what Ford did differently between 4 and 5. Any DPC-462 PCM will work, but there may be a little difference.
Old Jan 6, 2009 | 05:34 PM
leekingen's Avatar
leekingen
LOOK IN car-part.com that' how i found mine. should get one cheep i would think.good luck
LittlePete
Oct 7, 2016 12:25 PM
Roy7.3
Nov 16, 2014 03:46 PM
Jbrown8988
Apr 5, 2013 09:04 AM
kennyr
Jul 9, 2011 11:25 PM
RussB
Jul 29, 2004 05:22 PM
