advice on guages
Old Jan 6, 2009 | 03:18 PM
brandon_oma#692's Avatar
brandon_oma#692
advice on guages
I would like to install a dp tuner f5 in my stock minus exhaust 1999.5 f250. Is something like the edge attitude ok to use in place of "conventional" guages? It seems like it would be easier to find a spot for than round guages. THANKYOU
Old Jan 6, 2009 | 03:41 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
It would work. The only thing people say about the digital gauges is that they are hard to read while at WOT. The regular gauges, all you have to do is look where the needle is and you know where you are at.
Old Jan 6, 2009 | 03:48 PM
Automator's Avatar
Automator
Welcome to FTE brandon_oma#692!
Old Jan 6, 2009 | 05:14 PM
big poppa's Avatar
big poppa
Welcome to FTE. Not bashing any of the digital equipment but i agree with Rick above, i like watching them needles move.
Old Jan 6, 2009 | 05:29 PM
SUPERDUTY OUTLAW's Avatar
SUPERDUTY OUTLAW
Go with the edge evo not the the juice it gives way better parameters to monitor the juice is very limited and yes they are very hard to read at wot but they do the job and the evo will start beeping if you get too high on any parameteres that you have set.
Old Jan 6, 2009 | 05:59 PM
Ponyboychris's Avatar
Ponyboychris
I like my "cockpit" look with dial gauges.
Old Jan 6, 2009 | 06:09 PM
aocabrown's Avatar
aocabrown
I've always heard that those types of gauges/ monitors get their info from the PCM and that the PCM is either not as accurate...or that the PCM is having things purposely modified / hidden from it by the chip that is installed. For these reasons, I've heard to go for the real gauges.
