ECM Swap - Drivability
Old Oct 4, 2016 | 03:50 PM
LittlePete's Avatar
LittlePete
Hello Gentlemen,
I need to swap the ECM (i.e. PCM/TCM) on my early 2004 F250 6.0. I determined the proper ID for the ECM and located a replacement.
My question, is it possible to swap it in unprogrammed so I can test for resolution of my issue and to take it to be programmed? I have heard various things even that only '05+ actually store things like VIN in the ECM.
- Pete
Old Oct 5, 2016 | 12:33 PM
Jeremy05's Avatar
Jeremy05
Is the new pcm from a wreck? So its already programmed? If thats the case put it in and run it for your testing purposes. Dont worry about the vin mismatch etc it will still run just fine...providing you matched up your pcm ID code.
For example I'm running a truck pcm in my excursion, for many reasons that are not important to your question...but it can be done.
Old Oct 5, 2016 | 01:47 PM
LittlePete's Avatar
LittlePete
Thanks Jeremy,
Yes it's used and matched the ID (3C3A-BDL). Was a huge pain determining that from just the VIN, when I called several Ford dealerships.
Good to hear that I can just slap it in and drive away.
What exactly does get programmed in the 03-04 ecm? I've heard the vin isn't actually stored in the pre '05 6.0L.
- Pete
Old Oct 6, 2016 | 03:40 PM
LittlePete's Avatar
LittlePete
ECM was a slightly older iteration. Had the previous ID iteration but started and ran perfect. Unfortunatly it did not solve my original issue.
-Pete
Old Oct 6, 2016 | 11:37 PM
Yahiko's Avatar
Yahiko
One of the things is the electronic features like ESOF and door locks
and stuff like that. Just make sure that the base types are the same.
You can't use a gas PCM for a diesel and you want the same trans.
But I could be wrong on some of that. Also you might get a CEL
do to programming version mismatch between the modules.
Sean <BR>
6.0L Tech Folder
Old Oct 7, 2016 | 12:25 PM
LittlePete's Avatar
LittlePete
Yahiko,
I said they're ecm worked
It just didn't solve my original issue.
gr8dain
Aug 26, 2018 01:13 PM
Tigauto
2004 - 2008 F150
Sep 17, 2016 10:05 PM
frmach
1997 - 2003 F150
Aug 12, 2012 06:21 PM
PHXDiesel
6.4L Power Stroke Diesel
Feb 2, 2009 10:06 AM
sammm
Computer Chips & Tuners
Apr 3, 2008 08:29 AM
