Stock puke/coolant can?
Old Jan 6, 2009 | 02:58 AM
crazedfox's Avatar
crazedfox
Exclamation Stock puke/coolant can?
Ok,
__I got something from the bone-yard is what seems to be a stock overflow/coolant tank.
When I saw this next to the radiator in a '74 I thought to myself:
What the heck?, Is this a stock overflow tank?
After I finnished cruising the yard for what I wanted, I came back & pulled the tank.
Then brought it home to find out if anybody else has seen or have one of these.
Say N.D. this is for you-
part no# seems to be:
D1TA-8C45-AB
This is the best I can make out on this thing.
I far as I know' there is no such thing as a 'I' in ford 'ID' code,
So this is why I think the "whatever" behind the 'D' is a 1.
As for everyone else, here is some pictures of my find.
Enjoy.
Old Jan 6, 2009 | 09:14 AM
crazedfox's Avatar
crazedfox
Could,
__somebody get NumberDummy's
help here please.
Old Jan 6, 2009 | 10:15 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Nice and compact. I am very curious what that thing is, as I thought our truck did not originally come with overflow tanks.
Josh
Old Jan 6, 2009 | 01:46 PM
crazedfox's Avatar
crazedfox
This,
__is what I thought too.
Only NumberDummy can answer this one for us.
It would be nice to know that these trucks had an option like this.
& that I found one.
But if it turns out that this came from another vehicle that was in the ford family; this will still be usefull to know.
Becuase it fits these trucks so well. & I be willing to try locate another one.
Old Jan 6, 2009 | 02:48 PM
Alvin in AZ's Avatar
Alvin in AZ
Yeah but. :)
Mine doesn't over flow. :)
But then.
Mine's never filled more than half way between the top of the ribs and
the filler neck neither. ;)
YMMV
Cool find tho and will be interesting what Bill's got to say about it. :)
Alvin in AZ 360FE T18 thintank4core FlowKooler12fin RobertShaw195*F
Old Jan 6, 2009 | 02:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by crazedfox
This,
& that I found one.
Sorry for the delay, it seems FTE is having server problems again.
D1TZ8A080A .. Coolant Recovery Reservoir / Obsolete
Fits: 1971/72 F100/250 240 I-6 // 1973/74 F100 240 I-6 w/a 3 speed M/T.
Fits: 1971/74 E100/300 240 I-6. E = Econoline.
I located two NOS.
Miller Obsolete Parts in Binghamton NY has ONE = 800-546-7278
Dennis Carpenter's Ford Obsolete Parts Dept. in Concord NC has ONE = 704-786-8139
That's it. No Ford Dealer or other obsolete parts vendor has any.
Old Jan 6, 2009 | 05:15 PM
4x4 Bart's Avatar
4x4 Bart
I have never seen one. Learn something new every day. I'm running one of a Chrysler. I'll have to start looking in the bone yard.................bart
Old Jan 6, 2009 | 06:11 PM
Bullitt390's Avatar
Bullitt390
Overflow tank for little 6 bangers, but none for a V8? Hmmmm interesting indeed.
Old Jan 6, 2009 | 06:58 PM
Alvin in AZ
"little hot water six :)" ?
Old Jan 6, 2009 | 07:13 PM
NumberDummy
2973/79 F100/350 Coolant Recovery Kit / 1978/79 Bronco / 1975/79 E100/350
Not quite...
DOAZ8522A .. Coolant Recovery Kit ~ Available at the Ford dealer parts counter / Obsolete
Fits: 1973/79 F100/350 / 1978/79 Bronco / 1975/79 Econoline / And anything else that didn't come with a factory installed coolant recovery reservoir.
A similar kit was sold by autoparts stores.
DOAZ8522A =
Ed Bennett Ford Parts in Lebanon PA has ONE = 717-272-8762
JST Automotive in Lebanon TN has ONE = 615-443-3086
Alvin in AZ nailed it.
D1TZ8A080A = the reservoir used in some 6 bangers was a Ford "campaign fix" for overheating engines.
Old Jan 6, 2009 | 08:19 PM
Bullitt390's Avatar
Bullitt390
Anyone got a picture of the second overflow tank?
The one I recently removed from my truck was probably about as close to factory as it came, but did not have any markings on it.
Old Jan 7, 2009 | 07:18 AM
crazedfox's Avatar
crazedfox
Thumbs up
Thanks,
__Bill. It did come off a '74-"six".
If it did have the original radiator; I think I know 1 of the reasons why it overheated. The radiator is kinda' small.
Thanks, again.
Old Jan 7, 2009 | 09:28 AM
crazedfox's Avatar
crazedfox
Question What?
[/quote]reservoir used in some 6 bangers was a Ford "campaign fix" for overheating engines.[/quote]
What is this "Champaign Fix" ?
I understand that it is a type of band-aid fix,
But I would enjoy a little more depth on this term.
Old Jan 7, 2009 | 10:16 AM
NumberDummy
I understand that it is a type of band-aid fix. But I would enjoy a little more depth on this term.
Before there were mandatory recalls, Ford sent out a campaign letter to dealers advising them of a particular defect.
It was then up to the dealers to notify the customers of the defect.
Here's one example of a campaign letter.
The 1968/69 and some 1970 car/truck ignition switches (C8AZ11572A) SHORTED OUT AND CAUGHT FIRE!
(ALL 1968/69 F100/750's & Econolines, 1970 F100/750's and Econolines before serial number G90,001).
Ford replaced all these switches for free whether the vehicle was still under warranty or not.
But remember...it was up to the dealers to notify the customers, and if they didn't do that, this faulty switch may still be in these vehicles today.
The fix: D1AZ11572C .. Replacement Ignition Switch (Motorcraft SW1054) This new switch comes with a pigtailed wire plug.
This switch is still available from Ford.
How does one know if the switch was replaced?
If the plug's wires are not spliced into the main dash loom, it's the ORIGINAL switch!
btw: I have posted this info inre to this faulty switch several times in the 1967/72 forum.
Old Jan 7, 2009 | 10:59 AM
hotroddually's Avatar
hotroddually
i have an overflow reservoir somewhere in the shop . when i get a chance to look for it i will. the part number is molded in the plastic tank i assume? when i find it, i will post any part # i find on it. if its the one thats factory for our trucks,i will post a pic too.
