Grill backer to protect intercooler.
Old Jan 5, 2009 | 08:00 PM
jamie7375's Avatar
jamie7375
I saw a backer for the bacl of your grill a while back but have not seen one lately. my intercoller is getting eat up with bugs and such. anyone know if you can still get them or am i just crazy...
Old Jan 5, 2009 | 10:33 PM
mhoefer's Avatar
mhoefer
Buy a 4 * 6 foot section of plastic bug screen, slide it in there, hose it off once in a while. Dont use wire, it will wear through and cut things.
Old Jan 6, 2009 | 08:27 PM
jamie7375's Avatar
jamie7375
thanks. ill try that and se how it works out.
Old Jan 7, 2009 | 10:05 AM
cartmanea's Avatar
cartmanea
I've been wanting to get something to cover the entire front under the grille and down to the blocker beam to protect the AC condenser and other parts from rocks. I don't think plastic screen would be strong enough, any ideas? If I go with a metal screen (like 1/4" openings) I'll make a frame and mount it so it wouldn't rub on anything. I just can't seem to find the right kind of screen material.
Old Jan 7, 2009 | 10:20 AM
barnbridge's Avatar
barnbridge
Check out this thread. I've done the gutter screen mod and it works great. You have to take off the front grill and glue gutter screens over the openings in the grill. The last post gives a link to pics.
Old Jan 7, 2009 | 10:31 AM
jamie7375's Avatar
jamie7375
Thanks for the idea. For some reason I can not pull up anything..
Old Jan 7, 2009 | 02:58 PM
barnbridge's Avatar
barnbridge
OOps, forgot to post the link:https://www.ford-trucks.com/forums/1...grill-mod.html
Old Jan 7, 2009 | 05:28 PM
jamie7375's Avatar
jamie7375
Originally Posted by barnbridge
Thank you very much...
Old Jan 9, 2009 | 06:23 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
I just took off my entire front grill and used ordinary window screen from Home Depot. Get the black color stuff.
Lay your grill face down on a blanket on your work bench. Mold and cut the screen to fit and use small zip-ties to secure (you'll figure it out). Replace grill and your set.
For my '03 Excursion it covers the entire front grill area except for a very small area just below the grill (by the fog light and license plate area). Has worked for several years and does not interfere with cooling flow.
Good luck.
Old Jan 10, 2009 | 05:44 AM
jamie7375's Avatar
jamie7375
Thanks alot...Great idea..
Old Jan 12, 2009 | 01:54 AM
powerstrokeforever's Avatar
powerstrokeforever
Smile
The only problem with window screen is it will clog with snow in a storm. I used wire plaster lath for mine tough as nails, won't rust. just sharp as hell when you put it in. get the ban-aids ready!
Old Jan 12, 2009 | 10:30 AM
Dogwood36322's Avatar
Dogwood36322
I took my grille out and used the metal that is used as a backer for bathroomn tile. I is strong and has not rusted in 2 years. I comes in a 3"X6 or 8" piece. You can buy at Lowes or Hone Depot. Looks good and stops rocks well.
Old Jan 12, 2009 | 10:00 PM
mhoefer's Avatar
mhoefer
Your wire will eventually wear holes in aluminum where it rubs, especially sharp ends where you have cut, I have seen people put plastic edging to prevent these issues but its not fool proof. I have used plastic for that reason. It is away from all the parts, its going to take a large rock to push into the condensors and cooler which are another 3 - 4 inches. Its cheap and effective, up here we have gravel and rocks on our paved roads spread for winter. Mine looks brand new behind there and its never been clogged up with snow, and we have 5 feet already. Good idea to tie to the back of the grill but a lot more complicated than putting it back there with 4 zip ties. Its been there since March of 2005. No holes in cooler, no a/c issues, no rocks through anything so far so good. Simple, inexpensive and effective.
Old Jan 13, 2009 | 05:30 AM
jamie7375's Avatar
jamie7375
What plastic are you useing. Where did you get it...
Old Jan 13, 2009 | 02:42 PM
cmcowboy's Avatar
cmcowboy
Yes what plastic are you using and where do you get it? I have tossed around the idea of ordinary screen behind my grille, but here in Florida in the summer when it gets 95 to 98 degrees i start to wonder if the regular screen would restrict any air flow to keep her cool while I'm towing!!
