B code injectors.
Old Aug 26, 2009 | 05:38 PM
TheTowingCowboy's Avatar
TheTowingCowboy
B code injectors.
I will keep it short and sweet, what are they exactly and are the streetable? Cause I fell in love with Bean Performances Stealth Stage 2 pump, and it says for b code injectors and I want some b code injectors just so I have a reason to get that sexy looking pump. Thanks guys.
Old Aug 26, 2009 | 08:57 PM
redone1's Avatar
redone1
stay single shot IMO, just go bigger. atleast that's what i think after reading you want to pull it
Old Aug 26, 2009 | 10:33 PM
BlueMule's Avatar
BlueMule
Your truck isn't ready for B's. They're stock injectors for a DT530 and flow 260cc. In order to run them you'll need a bigger turbo, the stealth pump, electric fuel system and some custom tunes on a real chip.
Old Aug 27, 2009 | 06:09 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
B codes are for extreme high performance applications.
Besides that you must have a set of B codes to build or if you go new, you need to send a set of B codes in for cores. So unless you have a set already, for dirt cheap, then you're looking at spending twice the money for something that is marginally better (if at all) than a regular 'ole Hybrid.
There are only a handful of guys running B codes and doing well with them, but there are hundreds of guys with Hybrids doing really well.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
