I had a burned up headlamp connector last summer. No marker lights because the wire was burned up. I was able to get a new connector from Autozone, and I replaced the switch too.
Now I've replaced the headlamp switch twice, picking two different brands because the headlamps will blink once in a while on high beam. Anyone run into this? I'm assuming it's the circuit breaker built into the switch cycling once in a while.
I've looked over the wiring harness, and I don't see an obvious short. Do headlamps bulbs sometimes draw too much current?
This is a pretty old article. (I didn't check the link)
But it is about the ford wiring on our trucks and how to redo it better.
This wont help your problem, but you were asking about the draw.
Perhaps this will give you a few more ideas of places to check.
If anyone is going to put in relays for their headlights, I'd recommend wiring a little different.
Backwards wire the lights! Feed constant 12V to the common terminal of each light. Then a relay for high and low beam grounds one of the terminals. This way, each headlight can get it's own fuse. If there is a short, one light still works on both high and low beam.
I've replaced the bulbs, 3 headlamp switches and gone over the wiring.
A few months after I replace the switch, the blinking starts and keeps getting worse on high beam. Never a problem on low beam.
I'm guessing that the newer switches are just crap and so I've now put a pair of relays in. I wired them Japanese style, with +12V fed to the common terminal. Each bulb has it's own fuse. The high beam or low beam relay grounds the high or low beam filament connection. MUCH better know.
FYI, I did find a bit of weird Ford wiring. The ground wire for the bulbs is a 20 gauge wire, and the ground wire runs in the harness in front of the radiator and back before grounding. I'd guess this was to limit the voltage to the bulb for some reason.
I had a problem like this with an old tow truck 7.3 idi I use to drive. b/c there were so many add on after factory lights the lights would flicker. The switches went bad alot, several times a year. Just before I left they said they gave me a ambulance type switch. I worked there for a few more months w/o a problem. I don't know if it fixed it or not but it seemed to last longer than the standard switch. Just my 2 dinars
