Sponsored by: Real Truck
interesting drivline noise
Old Jan 3, 2009 | 10:11 PM
Toyman's Avatar
Toyman
I have a noise coming from the driveline. It is a squeek like that of a bad u-joint. All the joints are free and move smoothly. I hear this noise anything from 20 mph all the way through highway speeds 70+. Everything on the truck is tight, the noise does not change when brakes are applied. The only thing I haven't looked at (since last year) was the rear end. My truck has the 4.10 LS, it is a 99 F250 4X4 with the 5.4L.
Do you think I could be getting a noise from the clutch plates in the limited slip diff? The truck has almost 160K on it, this is the last thing I could think of for the noise.
Toyman
Old Jan 3, 2009 | 10:22 PM
kelly67's Avatar
kelly67
20 and up is odd! have any brake work done? thinking a dust cover plate may have been bumped and rubbing
Old Jan 3, 2009 | 10:32 PM
Toyman's Avatar
Toyman
Nope nothing like that. I replaced the rear calipers last winter, I had one lock up one night plowing. Also did new pad, anti rattle clips, rotors.
I'm really leaning toward something inside the rear axle. But there is really no way to listen to it with stethiscope. I can't duplicate it with the truck jacked up.
Old Jan 3, 2009 | 10:40 PM
kelly67's Avatar
kelly67
160,000 ever change lube in the axle? if not I guess it wouldn't hurt. fairly cheap.
Old Jan 3, 2009 | 10:50 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
sound bad pinion bearing that hook to driveshaft in rear.
Did you slam on gas pedal when plow snow it must be something to messy pinion bearing.
how many miles on it.
Did you see any driveshaft rubbing?
Old Jan 4, 2009 | 07:05 AM
Toyman's Avatar
Toyman
Yes I change lube annually. I installed an aluminum cover (from Off Road Unlimited) with extra fluid capacity two years ago, there is friction modifier in with it.
The noise didn't just come around recently. I have been plowing with this truck for 2 years it has been there since last year. It is just really bugging me that I can't find it, or pin point it.
I'm not sure how you plow Mil, but I am the only person that drives my truck. In the last 15 years of pushing snow, I have never broken anything.
Old Jan 4, 2009 | 02:50 PM
Milwaukee1979F150
My friend would slam on gas pedal when it 5 feet away snowpile and ram it that how it cause. I am sure you plow ok but he not plow easy HARD ON IT.
Can you check driveshaft if it rubbing anything? I have one truck that would do make noise like squeal it was exhaust pipe too close driveshaft when I have 1,500 pound on bed so driveshaft change angle and touch driveshaft.
Old Jan 4, 2009 | 03:37 PM
Toyman's Avatar
Toyman
Still has original exhaust. There is nothing rubbing anywhere. I have been actively trying to search this noise for about a year. It really doesn't impede performance, it's just annoying.
Old Jan 4, 2009 | 05:42 PM
Steve_250's Avatar
Steve_250
Have you dropped your spare and reseated it?
The spare WILL squeak....(drove me crazy looking for the squeak)
I dunn'o, just reaching here....
Old Jan 4, 2009 | 06:11 PM
Toyman's Avatar
Toyman
Good thought, but no spare. No mount. No brackets.
Old Apr 6, 2009 | 08:47 AM
xjoedirt55x's Avatar
xjoedirt55x
I am having the same problem. Mine starts squeeking after I get to about a 5mph roll, then dissipates when I hit around 50mph. Mine sounds like it is coming from the rear, but just have not had a chance to dig into it yet. Mine squeeks worse when I am on the gas. I use my parking brake pretty often, and seems to be working just fine, so I do not see that being the issue.... with mine anyways. I am leaning/hoping towards it just being some sort of metal rubbing on my rotor and it being a cheap/free fix. How hard are the rear u-joints to replace on the rear ends of these?
Old Apr 6, 2009 | 08:57 AM
FortyFords's Avatar
FortyFords
There was a tsb on this yrs ago ,A squealing noise can come from the front wheel bearing seal in the knuckle ,its the big seal on the back of the knuckle that keeps the water out of the wheel bearing hub.
Take a some spray silcone ,with those little red tube so you can direct the spray where you want it an spray the area of the seal to see if the noise goes away.
Becareful not to get it on your rotors.
If it goes away you have found your problem.
But to fix it ,replace the seal (not a fun weekend job)
Rich
Toyman
Michigan Chapter
Jul 6, 2010 01:04 PM
Toyman
Nov 30, 2009 08:57 AM
Toyman
May 20, 2008 09:16 AM
Toyman
Garage & Workshop
Mar 19, 2007 09:36 AM
