Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
looking to buy log splitter
Old Mar 12, 2007 | 08:52 PM
Toyman's Avatar
Toyman
I'm thinking with almost 20 acres of woods I could put a log splitter to use. What would your thoughts and advise be on a log splitter?
Looking forward to hearing from personal experiences.
Toyman
Old Mar 12, 2007 | 09:43 PM
havi's Avatar
havi
I'll have the Roast Duck
I use a 12lb maul. But I have black ash, maple and birch...easy to split. Oak, forget it. Cheapest I've seen is from the HF catalog.
Old Mar 12, 2007 | 10:17 PM
wreckit72's Avatar
wreckit72
I bought the 35 ton log splitter from Tractor Supply last fall. It has a 16 GPM pump, 13 horse engine, and a 5 inch cylinder. It has split about 10 cords of oak without a problem. It is made by Speeco Products not MTD. I did a lot of looking and the TSC splitters are a good value for what you get.
Old Mar 13, 2007 | 12:07 AM
Ford_Six's Avatar
Ford_Six
Check with equipment rental companies. Most of what they have is decently maintained, and something like a log splitter would be ok to buy used- any damage would be pretty obvious.
Old Mar 13, 2007 | 04:19 PM
sublimecharger68's Avatar
sublimecharger68
I split Oak by hand.
You just have to be able to hit the same spot twice. LOL Though some chunks get more attention with a saw and you have to pay attention when making your blocks to cut them to your splitting advantage.
I burn around 12 truck loads a year to heat my house my dad burns about the same amount and also sells 10 truck loads a year and most is all split by hand. Though we due have a 3pt Mounted Splitter but often times that is a hassle to use.
Though this summer I borrowed a 27Ton 2 positon splitter from a buddy to use on my Elm Tree that the power company had cut down due to power line interference. and that 2 postion was great for having the splitter vertical and then wrestle the big blocks into positon to make them small enough to handle.
sublime out.
Old Mar 13, 2007 | 08:33 PM
Toyman's Avatar
Toyman
I just got home from TSC and read these posts, I was dealing with the manager on the same splitter. I got her to $1399, she knocked
$200 off the price and I got her to throw in extra hydraulic oil and a rake. Is this a good deal?
Toyman
Old Mar 13, 2007 | 10:39 PM
jake00's Avatar
jake00
ask the guys over at hearth.com, in the gear forum. lotsa guys running splitters
Old Mar 13, 2007 | 11:09 PM
wreckit72's Avatar
wreckit72
I would say that sounds like a pretty good deal.
Old Mar 14, 2007 | 07:30 AM
ckal704's Avatar
ckal704
If you can be patient, you can do better than that deal.
I bought mine from a local rental place for $300.
It is a 20 (maybe 25) ton splitter. The reason I don't know is that I don't care about its rated capacity because I have never stalled it or encountered something that could not be split with it.
I used to split by hand, but I get a good bit of my wood when it is available from folks wanting a tree down and I split it asap so it dries faster. Pretty tough to split green wood with a maul sometimes. Black gum is impossible to split by hand even if dried for 2 years!
One also gets more usable wood from a splitter. Crotches and limb riddled logs can be broken into sizes that will fit into the stove whereas when I split by hand most of that stuff ended up in the burn pile out back.
Old Mar 14, 2007 | 03:57 PM
F250FarmBoy's Avatar
F250FarmBoy
I bought my home-made log spitter at an auction and it was a steel "I" beam with a wedge welded on one end and a hydralic ram on the other, it was powered by an old 5hp Briggs and Straton engine, but I just switched it up to allow for it to be run off the tractor's own hydrulics...no engine, pump,or tank, just 2 hoses.
That sucka will split any thing I throw at it, except 2' wide elm(that stuff takes a pounding before it even begins to crack)
But I can't really help you when it comes to the store bought kinds, I just wanted my mouth to do some arobic exercise..lol
Old Mar 14, 2007 | 08:24 PM
Ferguson65's Avatar
Ferguson65
We have a 22 ton 6.5 hp we got used from a rental company for 750. It has been great! Will split anything your can get to it, and we've thrown some big logs at it. My best piece of advice, get one that is converible from horizontal to vertical, that way you can just more the big logs with a bar and not pick them up. The ability of ours to do that is great, and I'd never get one any other way.
Old Mar 18, 2007 | 11:23 PM
wreckit72's Avatar
wreckit72
Toyman, have you tried out that new splitter yet?
Old Mar 19, 2007 | 09:36 AM
Toyman's Avatar
Toyman
I worked the splitter yesterday. Very impressed with the Husky, the engine never seemed to bog down. I split about a cord of wood.
Thanks for everybodies help and ideas.
Toyman
jgavac
Garage & Workshop
Jan 17, 2013 01:24 PM
Flexfuel-Dave
Feb 24, 2011 11:43 PM
ckal704
Garage & Workshop
Nov 22, 2009 04:00 PM
Toyman
Michigan Chapter
17
Jun 14, 2008 01:34 PM
