c6 id #'s
Old Dec 23, 2008 | 12:15 AM
glarusguy's Avatar
glarusguy
c6 id #'s
Just picked up a c6 for my 460. Was told it is out of a 1 ton van. The ID tag reads: PJD E1 FC 068623. It is for sure the big block housing. Just wondering if the numbers will tell me anything else. It also has a 17 some inch tailhousing with angled mounts. Thanks.
Old Jan 9, 2009 | 09:00 PM
glarusguy's Avatar
glarusguy
No..? Lets try this then. What I really need to know is if anyone has seen a c6 transmission that has a tailstock that is 17 inches long and has mounts that are at a 45 degree angle? I looked thru a whole transmission mount catalog and didn't see a single one that looked like it. Thanks again.
Old Jan 9, 2009 | 11:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Econoline? Not!
I was suspicious the second I read that angled mount reference.
PJD-E1 = 1972 Lincoln Continental Mark IV & Town Car, both w/a 460.
It took me 30 minutes to find that damn code, because I first looked in all the truck parts catalogs from 1964 thru 2002...nothing.
Then I looked thru all the Ford car parts catalogs from 1965 thru 1979...nothing.
After looking in the 1973/79 L/M parts catalog, I finally found it in the 1965/72 L/M parts catalog.
You just don't look up that code...it's only listed under the YEARLY application charts, and there are 100's!
And the codes aren't listed numerically, there's a ref to a PJD-D code in the 1980/89 truck parts catalog.
Old Jan 11, 2009 | 07:44 PM
glarusguy's Avatar
glarusguy
Thank you!!
My great thanks and apologies. Thank you for the info and trudging through the numbers. My apologies for the misdirection. The life of any part is interesting I guess. The guy told me it came from a van, but then I suppose before that is was in a Lincoln...or whatever...but initially a Lincoln. Now I can go in find the right mount!
