I have a 1967 Oldsmobile that would never be a daily driver and antique tags would be very suitable...if I can still get them when the car is ready. I saw antique tags on a chevette the other day - geeze. 250 miles a year is the limit, you can't haul ANYTHING on an antique truck, and I agree Franklin2 and Bashby. Using antique tags just to modify or to get out of fixing your truck is abuse. I'm sure the Stae Police would love to see my Antique tagged F350 pulling my Antique tagged Olds followed by my wife in my Antiqued tagged F100 to the dragstrip. That'd be a hoot.
Because of people like what? You yourself have admitted to disabling your own smog equipment in previous threads! What makes you assume that I am planning to use this truck for any other purpose than to drive my sick grandmother to her doctor's appointments? Or to use it as radical, one-off custom show truck? Who made you the DMV's Proper Antique Vehicle Usage Enforcer anyway? Your tone is elitist and highly curmudgeonlike...Get off your high horse, get off the computer, take your Benefiber, and go to bed...
You are correct, I am guilty of taking smog equipment off, and I can make excuses for doing that, but it doesn't excuse me from breaking the law as you mentioned.
There are as you said legitimate reasons for having antique tags, but your response was pretty general with no mention of the rules, so that's why I jumped on it. Sorry about that.
It's not plumbed at all. There's a spark plug plugging the hose right off of the valve. If it's above 40 tomorrow I'm going to see what I can see, maybe take a few pics to post and see if someone can decipher what the problem(s) maybe.
Well, if it doesn't have a vacuum source, about the only way it could cause a problem is
if it's stuck (partially) open. Even if the gasket between the mani & plate were shot, I
doubt it'd leak enough into the intake to make a difference.
If it were me, I'd hook that diaphragm up to a vacuum source and make sure the thing
opens with vacuum applied & closes with it removed.
A bad idle can be caused by a lot of different things, what made you suspect the EGR?
-ct
I suspected there was a problem before I bought the truck and the previous owner started with removing the egr - half a** at that. Really don't think it's causing any problems. I'm leaning toward vacuum and choke issues.
bandi, I think you are confusing the egr with the air pump system. The egr is the valve attached to the plate under the carb with one vac. line attached. If it has no hose hooked to it, the truck will run the same unless the egr valve is stuck open (rare thing but it would idle poorly if at all then run good or better off idle. The air pump is belt diven and pumps air into the 4 fittings on each exhaust manifold, through various tubes and check valves. On a truck with a catalytic converter, the theory is adding oxygen helps the converter burn off the leftovers from combustion. On the F350's in 86 and ther abouts (I know thats not a word), a catalytic converter was not required, so as best as I understand, the air pump was only there to dilute the tailpipe emissions by increasing the ppm of clean air and reducing the ppm of bad emission stuff. So by eliminating the whole air pump system you are not increasing your emissions, if you were to measure in "parts per mile" or "parts per revolution"
Indeed, I owe everyone an apology. Had it not ben so cold I would've looked at the truck and saved a lot of confusion. I figured most of it out, check me unde "Ah Hah" thread.
