Why I Hate State Inspection
So, a) Why did my power steering do that? and b) Where can I find original wiper blades and/or arms? The junkyard obviously would have them, but are there any companies out there that make new "original" blades?
Here in Virginia, a garage that does state inspections has to have a dedicated bay and a employee for inspections. It's against the rules to have to wait for an inspection because they are doing an oil change or something.
I would check the belt tension on your power steering pump.
I'd take the truck back with the broken blade.....tell them to give the original back, which I believe is required by law in some states, and a replacement for the broken POS.......
And then tell them it started raining and the wiper broke and you almost hit a child crossing the street because you couldn't see.......
Which does not make me very "happy".
What about the classic cars with the original blades? Something needs to be done about this in my opinion.
'em once, parts that weren't even listed in the catalogs but they have 'em, found by calling
'em up and talking.
Another place I recommend is Rock Auto (also a sponsor here), I buy lots o' stuff from
them and they're also really helpful on the phone. I like them cuz they're a small, family-
owned business.
Calling up either of them doesn't get you to India.
-ct
What is this state inspection then - similar to our MOT (Ministry of Transport) tests?
This is what we are anually subjected to (in a nutshell) -
BRAKES
Anti-lock braking system (if fitted) Warning lamp is checked for:
• Function.
• Sequence of operation. Footbrake
• Reserve travel on the footbrake so that it does not go down to the floor
• Pedal rubber not worn to excess
• Correct operation of the servo assistance system.
This could be a handbrake or a footbrake.
Checked for reserve travel so that it does not reach the stops on application.
The mountings will be checked for security and /or corrosion.
• Master cylinder and servo unit are checked for fluid leaks with the engine on and the brakes applied.
• Servo unit will be checked to ensure it is operating correctly.
• Visible metal or flexible brake pipes will be checked for corrosion, condition, breakages or leaks.
With an assistant applying load to the
footbrake:
• Flexible brake pipes and any other metal brake pipes visible beneath the car are checked
• Disks and drums checked for condition and contamination
• Brake back plates and calliper securing devices are checked for condition and security
• Condition of the brake pads will be checked if visible
• An assistant operates the handbrake while the condition of the linkages and/or cables is checked.
• On some vehicles there will be a brake compensating valve beneath the car which will need to be inspected for fluid leaks
The performance of the front and rear brakes will be checked for efficiency and balance using specialised equipment.
Top of Page | FURTHER INFORMATION
<hr color="#791513"> DOORS
Both front doors must be capable of being opened from the inside and outside and all doors must latch securely.
Tailgates, bootlids etc.
All these items, including the tailboards and dropsides of trucks must be capable of being secured in the closed position.
<hr color="#791513"> EMISSIONS
<hr color="#791513"> FUEL SYSTEM
Any fuel leak will result in a fail. Checked under the bonnet and throughout the run of the fuel line from the fuel tank to the engine.
• The fuel filler cap must fasten securely
• The seal in the cap must not be torn, deteriorated or missing
• No other defect should be present which could cause fuel to leak out.
<hr color="#791513"> HORN
• Control should be easily reached by the driver.
• Volume must be sufficiently audible to pedestrians and other vehicles.
• The tone should not consist of a sequential multi-tone.
<hr color="#791513"> LIGHTS
• Operation.
• Condition.
• Security.
• Acceptable make/model.
• Dip and aim must be within specified perameters Stop lights, indicators and hazard lights*
• Lights,indicators and hazard lights must not interfere with each other whilst in operation.
• Indicators, stop lights and hazard warning lights function. Rear fog lamps**
• Must be fitted to the centre or offside of the vehicle.
• Tell-tale must work.
• Must not be affected by other lamps and not be obscured.
• Must be red.
There must be two reflectors fitted reasonably symmetrically, securely attached and not obscured.
* Must be fitted to all vehicles first used on or after 1st April 1986, but if fitted, must be tested.
** Must be fitted to all vehicles first used on or after 1st April 1980.
<hr color="#791513"> MIRRORS
• Visible from the drivers seat
• Not distorted or damaged so as to seriously impair the drivers view to the rear.
<hr color="#791513"> REGISTRATION PLATES AND VIN* (Vehicle Identification Number)
For registered vehicles the plate must be:
• Present
• Secure
• Not faded, dirty or obscured
• Be composed with correctly formed letters and spacing
• Permanently displayed
• Consistent · Legible.
<hr color="#791513"> SEAT BELTS
• Security and operation of the locking/release mechanism
• Condition of webbing
• Retraction of the belt (it is permissable to manually feed it in).
Notes:
1 For technical reasons the inertia locking mechanism is not checked.
2 On some vehicles the belt is attached to the seat, in which case the security of the seat to the vehicle would also constitute part of the seat belt check.
<hr color="#791513"> SEATS
• All seat backs must be securable in the upright position.
<hr color="#791513"> STEERING
• Steering wheel and steering column:
• Steering wheel condition
• The steering wheel must be securely attached to the steering shaft
• The upper bearings of the steering column are inspected for wear
• The steering shaft is checked for excessive end float
• Clamping bolts security
• The split pins and locking nuts
• The 'free play' in the steering
• Flexible couplings and universal joints.
Under the bonnet checks
Vary according to the vehicle;
Some of these items cannot be observed from under the bonnet on some makes and models. However in all cases checks
will be made for:
• The security of the steering rack or steering box and its mountings
• Any discernible play in the steering joints
• Swivel joints which form part of the steering system which can be readily inspected from under the bonnet will obviously be inspected.
More.. | Top of Page
• Wheel bearings are checked.
• Steering rack gaiters/front outer constant velocity joint boots are examined.
• Metal and rubber bushes are checked as
• All the steering joints.
• Power steering systems.
• Security of attachment of the steering rack or steering box is checked both with respect to tightness of the nuts and bolts, and structural cracking or corrosion of the vehicle chassis where it is attached.
• Also, split pins/locking nuts and other locking or retaining devices relate to steering components. Some cars have an element of rear wheel steering which is checked from beneath the car. The front suspension is checked, but also the rear for:
• Excessive wear to Wheel bearings.
• Condition of front drive shafts/CV joints.
<hr color="#791513"> SUSPENSION
• Upper suspension joints
• Any other suspension components which
can be inspected from beneath the bonnet
Both the front and rear suspension are checked to ensure.
• No split pins or nuts missing, no components broken or bent
• Road springs function effectively, no excessive wear
• Suspension joints function effectively, no excessive wear
• Shock absorbers must not leak and must be secure (the vehicle will be 'bounced' by the Tester to check that they damp the springs adequately).
<hr color="#791513"> TYRES/WHEELS
A failure with respect to tyre wear will result where:-
The grooves of the tread pattern are not at least 1.6mm throughout a continuous band comprising:
• Central 3/4 of the breadth of tread
• Entire outer circumference of the tyre.
• Type
• Size
• Structure
• Location on the vehicle with respect to the axles.
• General condition of tyre
• Condition of valve
The condition of the spare tyre is not part of the MOT.
Inspection to reveal:
• Damage
• Distortion
• Cracks
• Distorted bead rims
• How securely attached to the vehicle
• No wheel-nuts or studs missing
<hr color="#791513"> VEHICLE STRUCTURE
• The vehicle body must not insecure or displaced so as to constitute a risk of loss of control of the vehicle when driven, or a danger to other road users.
• There must be no dangerous sharp edges or projections caused by corrosion or damage
A vehicle can fail with respect to corrosion for:
• Excessive corrosion in a 'prescribed area' - within 30 cms of certain components, e.g. brakes, steering, suspension, seat belt mountings etc.
• Excessive corrosion in a 'prescribed area', but which is likely to adversely affect the vehicle's brakes or steering.
'Excessive corrosion' can mean a hole or a significantly weakened structure.
This is what we are annually subjected to (in a nutshell) -
For all you "anti-government" guys who think inspections are contrary to some basic "liberty", if you notice all rules and laws are a reaction to something happening. If you have ever worked at a factory for along period of time like I have where they have a "book of rules", you can watch it get thicker and thicker, year by year, because of people trying things they shouldn't be doing.
To keep people from running on bald tires, with doors that won't shut and frames that are rusted out with no brakes, they had to do something to keep these crazy people from killing someone besides themselves. If they were the only people on the road, it really would not matter would it?
Oh - I forgot - we do have mandatory insurance; but, it's not checked when you renew your plates.
