Transfer Case Motor/Actuator
Old Jan 1, 2009 | 05:57 PM
bigk_54's Avatar
bigk_54
I just replaced my hubs with Waren Prem. cause I thought my hubs were shot and now believe that it is the Tcase motor. I started looking around and Ford wants like 450$ for one HOLY BS! I found a few on the net for cheaper any advice on which way to go??
FORD EXCURSION 4X4 TRANSFER CASE MOTOR ACTUATOR at MONSTER AUTO PARTS
Shop 1A Auto® for Ford Excursion Super Duty Trucks Transfer Case Shift Motor 2+6 Pin Connectors 1999-06
eBay Motors: 00 01 02 03 Ford Excursion Transfer Case Actuator Motor (item 310110754127 end time Jan-21-09 03:24:10 PST)
OR Advanced Auto has a Dorman for like $170
Thanks
Old Jan 1, 2009 | 06:01 PM
vettdvr's Avatar
vettdvr
Check Ebay Item 310110754127
Condition: New
Manufacturer Part #: YC3Z-7G360AA
Old Jan 1, 2009 | 06:31 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Why do you think its the motor? Can you give more systems of your problem?
Old Jan 1, 2009 | 07:11 PM
CanadianSmokie's Avatar
CanadianSmokie
From what I've read and what happened to me was when the actuator motor stops working the light on the dash no longer illuminates.
I assume when the vacuum system stops working, the only indicator is the by-passing vacuum to the heater vents.
Old Jan 1, 2009 | 07:31 PM
miller_feed
The vacuum is still working when your ac goes to defrost. This means you have a vacuum leak in the vacuum lines going to the hubs. Look at these lines and make sure you don't have a leak. If you can stand outside your truck and turn the switch to 4x4 and hear the motor run, all is good on that side.
Old Jan 2, 2009 | 09:11 PM
bigk_54's Avatar
bigk_54
It will go into 4wd bout once a month and and it goes into 4 low about twice a month. Before it started being WAY speratic Ive had it not dis-engauge and had to tap on it to get it to dis-engauge.
Old Jan 2, 2009 | 09:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I started looking around and Ford wants like 450$ for one HOLY BS! I found a few on the net for cheaper any advice on which way to go?? Thanks
$450.00?
If you buy the same Genuine Ford actuator motor from an FTE sponsor, you'll save over $150.00!
YC3Z7G360AA .. Actuator Motor Assy. (YC3Z7G360AA replaced: F81Z-7G360-AA)
MSRP: $539.89 / FTEpartsguy.com price: $291.54
FTEpartsguy: Ed Olson, parts manager of PARR FORD in Bremerton WA.
FTE has Ford Dealer parts department sponsors that give members parts discounts (as you can see) off the actual MSRP.
Why pay retail...or worse?
The link to FTEpartsguy is on this page among the sponsors.
Old Jan 3, 2009 | 12:08 PM
bigk_54's Avatar
bigk_54
Just tried it again put it in 4 high, nothing, put it in 4 low nothing, then I couldnt get it to come out of 4 low all it did was reduce the power
blowhole
Sep 20, 2023 10:55 PM
03_PSD
21
Oct 22, 2009 04:23 PM
Orange '63
May 26, 2009 09:47 AM
Chaosracing
Garage & Workshop
Mar 12, 2009 09:45 AM
oldgameandfishdiesel
Oct 22, 2008 09:25 PM
