Sponsored by: Real Truck
Steering stabilizer Question
Old Dec 31, 2008 | 03:23 PM
mikestoke's Avatar
mikestoke
Exclamation Steering stabilizer Question
I have noticed that the rubber bushings on my front sway bar are shot. Are the bushings replaceable or do you have to buy the whole bar? Thanks In advance Mike
Edit.... I am talking about my front sway bar. Sorry
Old Dec 31, 2008 | 04:20 PM
Fordfanatic4life's Avatar
Fordfanatic4life
NO.. u can buy aftermarket Urethane bushings that far excede anything the stock rubber bushings did..
check Energy suspension for one...
Welcome to Energy Suspension!
Old Dec 31, 2008 | 04:25 PM
mikestoke's Avatar
mikestoke
Ahh, Thank you , that is what I wanted to hear... Thanks for the link.. Mike
Old Dec 31, 2008 | 04:29 PM
sonneborn3's Avatar
sonneborn3
Unless you are talking about the end links, I could not find the replacement bushings for mine, just the entire end link for around $75 each.
Old Jan 1, 2009 | 08:14 AM
SGnAZ's Avatar
SGnAZ
Energysuspensionparts.com
They have a kit for your truck,someone on here did a real nice write up with pics on how to replace them.
Old Jan 1, 2009 | 09:36 AM
Furian's Avatar
Furian
You Keep What You Kill
Here is the link:
Ford Truck Listings Page 3
F350 4WD
<TABLE cellSpacing=0 cellPadding=2 width=530 align=left border=1><TBODY><TR><TD width=52 bgColor=#33ccff><CENTER>Year</CENTER></TD><TD bgColor=#33ccff><CENTER>Front Leaf Spring Bushing Set</CENTER></TD><TD bgColor=#33ccff><CENTER>Axle Pivot Bushing Set</CENTER></TD><TD bgColor=#33ccff><CENTER>Front Track Arm Bushing Set</CENTER></TD><TD bgColor=#33ccff><CENTER>Rear Leaf Spring Bushing Set</CENTER></TD><TD bgColor=#33ccff><CENTER>Body (Cab) Mount Set</CENTER></TD><TD bgColor=#33ccff><CENTER>Complete Front Sway Bar Bushing Set </CENTER></TD><TD width=46 bgColor=#33ccff><CENTER></CENTER></TD></TR><TR><TD width=52><CENTER>1999-04</CENTER></TD><TD><CENTER>4.2148</CENTER></TD><TD><CENTER></CENTER></TD><TD><CENTER>4.7126 (57)</CENTER></TD><TD><CENTER>4.2147</CENTER></TD><TD><CENTER></CENTER></TD><TD><CENTER>1 1/4" 4.5186 (123)
1 1/4" 4.5192 (123)(131)</CENTER>
</TD><TD width=46><CENTER></CENTER></TD></TR></TBODY></TABLE>
The only difference between the F250 4x4 and the F350 4x4 is the Front Track Arm Bushing Set, Part # 4.7128 and 4.7126 respectively. All other bushing sets were identical.
Also, there is a "Master Bushing Set" for the F250 4x4 which includes all possible bushings. However, this Master Bushing Set was not listed in the F350 4x4 section. The Master Bushing Set is Part # 4.18124. There is also a Rear Sway Bar Bushing Set that was only listed in the F250 4x4 section, Part # 4.5187 (123).
Happy New Year!
Old Jan 1, 2009 | 12:32 PM
89stinger's Avatar
89stinger
I replaced mine with an energy suspension kit and it worked great so far.
Old Jan 1, 2009 | 03:08 PM
fordf150guy's Avatar
fordf150guy
k guys get ready for a stupid question. why 2 different numbers for the sway bar bushings? one red one black? or are those the ID size? and whats with the numbers in brackets...wheel base? thanks
ohhh yeah...and i assume that the rear sway bar kit is the same for the 250 and 350?
Old Jan 1, 2009 | 08:27 PM
aldridgec's Avatar
aldridgec
The overall thickness of the bushing can vary, but I'm not sure of the application. Mine has the thicker bushing overall.
shaferz
Jan 25, 2011 07:51 PM
ah1988
Jan 13, 2011 06:45 PM
PbFoot
Dec 5, 2008 02:38 PM
jhoward
Dec 19, 2006 02:45 AM
Fishallot
1978 - 1996 Big Bronco
Nov 10, 2006 05:30 PM
