i need help finding the sway bar bushing bracket i cant find it at my local auto zone or napa the brackt is bent out of shape beyond belif so i need a new one i have the bushings i just need a new bracket for the front sway bar i got the 1 1/8 inch bushing .
Thank you for any help,
your looking for the rod itself or the bracket that adds it to the frame? if your looking for the rod then you can always just bend it back or cut out the section and weld in a new one. or get some tube that it will slip into and weld the ends to that. thats what im doing to extend mine. if you want new, lmc truck parts has them. dont recall how much
i am looking for the bushing braket the metal thing that goes over the bushing into the frame i am going to check lmc truck thanks i didnt think of them .
would the 250 braket be just as good as the 350 braket because they only have the one for the 250
here is the part number if you want to look at it 45-1439
