2000 Expy Turn Signals
Old Dec 31, 2008 | 07:01 AM
Bobkate6's Avatar
Bobkate6
The vehicle is a 2000 expy with 4w/d and a 4.6 windsor engine, vehicle has 200,000 miles. Here is the situation. I have no turn signals but do have emergency flashers and wiper function. I have replaced both the turn signal flasher and relay. I have also checked connections in steering wheel and they seem OK. Yesterday I was checking the flasher with a test light and when probing the turn signals both right and left worked with the test light connected. When I remove the test light the turn signals no longer work. Any ideas ?
Old Dec 31, 2008 | 08:01 AM
Frat-man-du's Avatar
Frat-man-du
Where were you probing? Did the turn signals work with the lever or just went using a test light. Oh and was the test light self powered?
Old Dec 31, 2008 | 08:36 AM
Bobkate6's Avatar
Bobkate6
I was using a regular test light( clip to ground probe to power light comes on.)I was probing the terminals at the flasher ,key was on and lever was in signal position. There was a wire for each side.
Old Dec 31, 2008 | 08:40 AM
Frat-man-du
Sounds like bad ground or power lead from the switch - would have to do one at a time to see which resolves the issue.
Old Jan 2, 2009 | 07:50 PM
Bobkate6's Avatar
Bobkate6
Thanks for the help, removed mulltifunction switch and found loose wire.
51camohunter
23
Jul 9, 2023 12:25 PM
eog037
General Automotive Discussion
Nov 26, 2016 07:24 PM
hdunlap
16
Nov 19, 2016 02:36 PM
meporsche
Apr 3, 2016 04:05 PM
lg3rd
Jun 16, 2015 02:29 PM
