Sponsored by: Auxito
transfer case fluid
Old Dec 30, 2008 | 08:35 PM
1986fordrangerman's Avatar
1986fordrangerman
transfer case fluid
I just changed the transfer case fluid on my 97 F150. I used Castrol Mercon V aft that says its good for Mercon or Mercon V specs. I've been reading that I should use only Mercon like the Dex/merc fluid. Will it be all right with stuff I put in or should I change it to the Dex/Merc. Thanks
Old Dec 30, 2008 | 09:25 PM
steve(ill)'s Avatar
steve(ill)
Mercon is being phased out and all new reference will be to MERCON V. EVERYTHING upgrades to the MERCON V. You did good.
Old Dec 31, 2008 | 06:02 PM
galaxie641's Avatar
galaxie641
Being in the transfer case it really doesn't matter, the only time you run into problems is with the E4OD and maybe one or two other transmissions that do not take Mercon V.
raptor131
Feb 27, 2013 10:00 AM
kd0axs
Oct 15, 2011 08:03 PM
Billyclub
Jun 7, 2010 08:49 PM
oldwood
Jul 16, 2009 10:28 AM
VORTMAX_99
May 4, 2009 10:19 PM
