1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
4WD System Indicator Light (4x4, 4-low) Intermittent
Old 12-30-2008, 05:05 PM
atrmg1610's Avatar
atrmg1610
atrmg1610 is offline
2001 F250 V10 Auto Manual Hubs & Floor Mount transfer case lever. Sometimes when I shift into 4-HI or back to 2-HI or to 4-LOW the light does not come on in the gauge cluster area. Sometimes it does, but doesn't turn off when I change modes. Any idea why?
Question 2: I figure with the floor mount transfer case lever it's still putting the truck into the right mode, right? I mean, it's not like a switch on the dash where you can't tell what's happening, right?
Old 12-31-2008, 11:08 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
There is a switch on the transfer case that turns on the light(s). Check the wiring, or replace the switch.
Yes, with the shifter, you SHOULD be OK without the light telling you it's OK
Trident
01-16-2015 10:20 PM
montego69
1997 - 2003 F150
08-02-2014 03:56 PM
afbrian13
11-02-2011 09:41 AM
76F250HighBoy
1978 - 1996 Big Bronco
10-25-2005 09:08 AM
blanes
11-07-2003 11:38 PM
Quick Reply: 4WD System Indicator Light (4x4, 4-low) Intermittent
