so I did some searching and came up empty....hopefully yall can help me out
Here is what is going on...
Whenever I shift from any drive gear (D, 1, 2, r) into neutral my rpms drop for a few secs but here is the new issue....
When my rpms reach around 2700-2800 my battery light comes on and and then the voltage meter jumps up way way high. Once the trans shifts everything goes back to normal....any ideas? I have no clue
Maybe a short in the mechanism that shifts the trans?
Does it happen before the trans shifts into every gear?
Cowboy Steve
well i dont ever end up with 2800rpms when I am in 3rd and 4th gear (I will see what i can do) but I know for sure that it does the light/voltage drop while in 1st and I will try it in 2nd when I run to sams tonight
Yep, check that and see if starting in 2nd and shifting to drive will cause a spike. Do you have any diffrence in your shifts? later, sooner, firmer, softer, slipping, etc.,?
the only idiot light I had flash was the battery light when I was having the voltage jumps. Now I have no volrtage jumps and no warning lights...just the strange shifting
