Trans Temp regulator valve???
Old Dec 29, 2008 | 11:44 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
Can anyone tell me if there is a reason why my tranny gets warmer in the winter time than it does in the summer while towing? The temps are as low as -22*C and my tranny can climb up to 160* with my TRU-Cool while, it babrely ever hit that while tugging in the 30*+ weather of the summer. Is there some kind of cooler block valve in the tranny that shuts the flow to the cooler? If so how does this work? Thanks to anyone in the know.
Old Dec 30, 2008 | 12:15 AM
clux's Avatar
clux
You are right, there is a thermal bypass on your transmission that bypasses the coolers depending on temperature.
Old Dec 30, 2008 | 04:03 AM
Tecman's Avatar
Tecman
It was explained to me that its not a thermal bypass, its a over pressure reliefe valve. I just replced that part on my trans. So if the fluid gets too thick and slow moving, the fluid will pop open the valve, bypass the coolers and fluid will still get to the back of the trans so it doesnt melt down.
Old Dec 30, 2008 | 06:59 AM
Izzy351's Avatar
Izzy351
It does both. 160F is nothing to worry about at all. Start being concerned when it gets over 200. Pull over if it gets to 220-230.
Also make sure the cooler fins are clean -- crud getting in there can keep them from working as well.
You can read about the bypass valve here:
http://www.dieselsite.com/index.asp?...ROD&ProdID=172
Old Dec 30, 2008 | 07:13 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by Izzy351
It does both.
It does NOT do both. It is ONLY a pressure bypass. Dieselsite believes otherwise, and I've tried to explain it to Bob, but Bob knows what he knows and is not open to those that might know more about transmissions than he does.
All that is in there is a spring and a ball. If there is too much pressure going to the cooler the ball pushes off it's seat and allows flow to bypass the cooler. When the pressure goes back down the spring pushes the ball back onto it's seat and all flow goes to the cooler. There is no thermostatic device in the 4R100 at all.
At -22C (-8F) it might be cold enough that dino ATF is getting too thick to go through the coolers, especially if there is any restriction in the coolers or the lines. This will make the bypass open. If it is opening because of this it will not close again until the ambient temperature rises. Even if the trans gets really hot the coolers won't see the hot ATF and will remain clogged. Once the bypass opens there is very little pressure in the cooler lines to push out the thick ATF.
Old Dec 30, 2008 | 11:37 AM
FactoryTech's Avatar
FactoryTech
Mark,
That's kind of confusing when it doesn't have to be. It's not reall important how it works, it was designed and installed to divert converter out flow to rear lube when the ambient temp is cold. WHile there isn't any kind of thermostat or thermocouple in it, the differences in fluid viscosity caused by air temps is why it works. Bottom line is, when it's cold outside, your converter out is sent back to rear lube in without going to the cooler, when it's real cold, it never opens up to the cooler at all and this is why sometimes you can run higher temps in the winter than in the summer. And if you cooler is clogged in any weather, it just might save your tranny by allowing some flow where a clogged cooler could shut of flow completely.
Old Dec 30, 2008 | 11:44 AM
DieselCamper01's Avatar
DieselCamper01
Originally Posted by FactoryTech
Mark,
I have to respectfully disagree. I really liked Marks explanation. Not confusing to me anyway.
Old Dec 30, 2008 | 06:18 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
Thanks for all the responses fellas. I was never concerned about the 160 degree temps, just curious as to how and why this occurred. Thanks for the insight Mark. I was actually hoping you would chime in on this as I know from past posts that you are in the "know" with transmissions, and I respect your posts very much.
Old Dec 30, 2008 | 09:03 PM
Izzy351's Avatar
Izzy351
Interesting. I missed this whole thing today. So it's PURELY based on cooler restriction -- good enough... That actually makes more sense, considering somewhat common failure that thing is. The sucky part is Mark's last paragraph. If dino fluid is cold enough to cause the bypass to open, it might never close again since the fluid will never be pushed through (also an EXCELLENT reason to run syn ATF!). I wonder if those of us with the tranny cooler in the radiator won't have the problem because eventually, the fluid in the lines WILL get warm from the hot coolant.
Old Dec 30, 2008 | 11:02 PM
Mark Kovalsky
No, that won't help. The radiator DOES NOT EVER warm the ATF. NEVER. The lines will NOT get warm from the radiator cooler.
If you want to know why, do a search. I've typed it WAY too many times lately and I don't want to type it again.
Old Dec 31, 2008 | 08:51 PM
Tecman's Avatar
Tecman
I thought the bypass valve was spring acuated so you shouldnt need fluid pressure going the other way to close it.
Old Dec 31, 2008 | 09:08 PM
Izzy351's Avatar
Izzy351
I'm not that interested, really. But it makes sense to me that if it's really cold out, as the truck warms up to temp, that some of that warmth in there will make it to the fluid. I'll take your word for it, but there has to be some heat transfer, if indeed the bypass is closed and there is no warm fluid from the tranny making it there.
Old Jan 1, 2009 | 08:09 AM
Mark Kovalsky
When it's really cold out the ATF can gel in the aux cooler. There isn't enough pressure in the cooler lines to blow it through before the bypass opens. Once the bypass opens there is very little pressure in the cooler lines, so there is even less pressure trying to force the gelled fluid through the cooler. Meanwhile the aux cooler is out front in the air stream, so even if heat reached it the below zero air rushing over it will keep it below zero, and the fluid stays gelled until the ambient warms up.
Old Jan 3, 2009 | 12:28 PM
BobBarry's Avatar
BobBarry
When I let my truck warm up on a cold (<10ºF) morning after the block-heater has been running all night, the engine oil will start at about 50ºF while the tranny fluid measures at ambient temp.
After it has warmed up so the coolant has risen to operating temperature, the engine oil will have warmed up to about 100ºF, and the tranny fluid will be reading about 50ºF.
You're saying the 40ºF in tranny-fluid temp is NOT connected with that fluid circulating through the now-warmed radiator?
As to the original topic, the 6.0L cooler may not have the same kind of restriction, as my tranny-fluid seems to circulate even when very cold; driving around town, it will eventually get up to the 110º-120ºF range, but no higher.
Old Jan 3, 2009 | 08:27 PM
Mark Kovalsky
No, I'm saying the radiator doesn't warm up. The engine warms up, but the radiator does not. The thermostat keeps the engine warm, but the radiator doesn't get hot. It cools the coolant inside. Since the thermostat is limiting the flow of coolant to the radiator the coolant spends a lot of time sitting in the radiator cooling down. Cold coolant in the radiator can't heat the trans fluid. Engine oil doesn't enter into this at all.
