starter keeps going out
Old Dec 29, 2008 | 12:31 PM
paul_scooter's Avatar
paul_scooter
Hey guys,
My starter went out for the third time. The whole engine was professionally rebuilt and i think they put the same starter back in. I took the starter in to
have it fixed. The Bendix spring broke again for the 3rd time. Is there a 12 volt version i can get that will hold up and last? if so can you point me to the site?
thanks.
Paul
Old Dec 29, 2008 | 12:37 PM
Fomoko1's Avatar
Fomoko1
Welcome aboard Paul.
This is in your 239 flat head?
Old Dec 29, 2008 | 12:52 PM
bobj49f2's Avatar
bobj49f2
The 6 volt starter should work just fine. I would look into the way the starter is mounted. There is a support bracket that runs from the top bolt on the rear of the starter to the one of the oil pan bolts. It may not look important but it keeps the starter straight and prevents it from spinning from torque. If this bracket is not there the starter could become cocked and causing the starter to bind on the flywheel slightly causing the spring to become stressed.
Old Dec 29, 2008 | 04:14 PM
petey shoes's Avatar
petey shoes
sounds like bob hit the nail on the head. if not, macs carries a modern bendix. have one in mine, works fine. just remember that if you go to 12 volt, you need more cca's to spin in cold weather.
Old Dec 29, 2008 | 06:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by petey shoes
.... just remember that if you go to 12 volt, you need more cca's to spin in cold weather.
Actually, you only need 1/2 the CCA at 12v. (Especially in Arizona!)
I'll tell you, besides the alternator on my flathead, the best thing I ever did for it was buy a gear-reduction starter. It lacks that puking-my-guts-out groan of the original, but is far easier on the battery, the flywheel, and everything else. It has a solenoid to engage the drive gear from the front of the flywheel, so there is none of that hanging up (after the third time that happened to mine in the winter, I had enough!). As a bonus, they weigh less than half of the stocker, not that it matters because I haven't had to do a thing to it in 5 yrs. Setting the stocker up in place, while keeping the end plates on and getting the long bolts started will give you the arms of a jabba-man in short order!
Old Dec 29, 2008 | 07:03 PM
paul_scooter
OK, i'll check that support backet, thanks.
Old Dec 29, 2008 | 07:04 PM
paul_scooter
Yes, my rebuilt 239 flat head.
Old Dec 29, 2008 | 07:06 PM
paul_scooter
I get my parts from LMC truck, can you give me a link to macs? thanks.
Old Dec 29, 2008 | 08:33 PM
Julies Cool F1's Avatar
Julies Cool F1
HI Paul,
Here ya go:
Sometimes if you put too many links on the posts get help until they are checked out. I'll add MACS, Dennis Carpenter, C&G and Sacremento Vintage for you (in that order).
http://www.parts123.com/parts123/yb....hPage~cadeffcF
http://www.parts123.com/PartFrame.as..._Ford_Products
C&G Early Ford Parts for 1932 thru 1979 Ford cars and trucks. We have Old Ford Parts, Classic Ford Parts, Antique Ford Parts and Vintage Ford Parts!
Sacramento Vintage Ford
Good luck with the starter!!!
Julie!
Old Dec 29, 2008 | 09:46 PM
paul_scooter
Thank you Julie, i ordered the catalogs.
Paul
Old Dec 30, 2008 | 01:21 AM
Julies Cool F1
Paul
They have online catalogues as well. Sometimes there is more in the printed ones. But at least you can get a quick check if you need a part and compare prices without your desk looking like that of an encyclopaedia salesman!
J!
glruff
Maryland Chapter
300
Aug 4, 2008 09:55 PM
PAUL_2
Jul 4, 2006 04:19 PM
Paul Therriault
27
May 23, 2006 09:57 PM
sneak
General Automotive Discussion
13
Feb 3, 2005 11:53 PM
Stauf
Oct 18, 2004 02:13 PM
