Battery Light Flicker?
Old Dec 31, 2008 | 10:21 AM
megawatt00's Avatar
megawatt00
Adam you can pick up a decent multi meter from Home Depot or Lowes. Try and pick one up that has a current clamp and is capable of reading DC amps. This is invaluable for trouble shooting on DC circuits (glow plug issues, battery drain, etc)
Old Dec 31, 2008 | 12:15 PM
clintbonnie's Avatar
clintbonnie
Adam.. I really like the digital voltage I got.. I just leave it plugged into my cigarette lighter all the time.. I can keep a eye on the Glow plugs operating (it will show a voltage drop to 11.5V) and the alternator charging voltage while I am driving... check out:
Digital Voltmeter, Plugs into 12 volt Cigarette Lighter Socket
Old Jan 2, 2009 | 07:46 AM
Adam0331's Avatar
Adam0331
Got my hands on a voltmeter and checked at the batteries and it reads 14.2. It hasn't flickered in a few days now so I'm not sure?
Old Jan 2, 2009 | 09:09 AM
tdpower's Avatar
tdpower
re
IIRC they should read 14.4 or higher at idle. It sounds like yours is starting to go south. How many miles do you have on your truck? Mine went out around 160k and I got that same flicker.
Old Jan 2, 2009 | 09:17 AM
just another truck's Avatar
just another truck
Originally Posted by megawatt00
Get it checked out right away Adam, A bad alt can take out your batteries with it.
May not even be right away.. could be a month down the line.. how would I know that.. and I took care of mine right away..
Trying a real slow trickle charge.. Wish I had more batteries to put in line.. oh well. My fingers are crossed.
Old Jan 2, 2009 | 09:19 AM
just another truck
Adam.. I was once told by a shop that he plugs on the back of alternators can come a little loose and give a ghost like flicker with no good reason.. check there.
Old Jan 2, 2009 | 09:50 AM
Adam0331's Avatar
Adam0331
Truck has 104,000. I checked the plugs on the back and they are good and tight.
Old Jan 2, 2009 | 10:09 AM
tdpower's Avatar
tdpower
I would check out your belt and pulleys if you have not already.
Old Jan 2, 2009 | 11:42 AM
clintbonnie
I think he is ok... 14.2 is in range... The voltage readings will change depending on several factors, such as air temp, condition of the batteries and charge. Mine varies from 13.8 to 14.4 all the time.
036.0stroke
Sep 25, 2013 10:07 PM
cutlass
Sep 23, 2012 11:17 PM
jt371
Mar 29, 2011 04:58 AM
Futuresweets-10
Nov 13, 2008 11:46 AM
95_4x4_jay
Oct 24, 2005 10:49 PM
