Battery Light Flicker?
Old Dec 29, 2008 | 11:10 AM
Adam0331's Avatar
Adam0331
I've noticed for a couple of days now when I am accelerating, usually over 60 mph, my battery light flickers. Could it be my alternator starting to go? I'd just like to get it taken care of before it leaves me sit somewhere. Thanks.
Old Dec 29, 2008 | 11:15 AM
Ponyboychris's Avatar
Ponyboychris
That's what my light was doing before the alternator gave up the ghost. Double check your battery connections to make sure they are good and tight with no corrosion.
Old Dec 29, 2008 | 11:26 AM
HH60FE's Avatar
HH60FE
Mine never flickered, just wouldn't recharge batt's. Didn't catch it till gauges went out and left me stranded at work. Dito what Chris said though.
Old Dec 29, 2008 | 11:50 AM
tdpower's Avatar
tdpower
Mine flickered when it went south. I would recommend a new one over a re-manufactured.
Old Dec 29, 2008 | 12:12 PM
clintbonnie's Avatar
clintbonnie
MIne was flickering and it was one of the two wires coming off the top of the alternator was shorting out the alum. housing, down about 1 &1/2" from the connector.. These two wires need to be a bit longer from the factory..
Another thing to check is the main wire harness that goes over the top of the driver's side valve cover.. read posts where it will rub on the cover and short out..
Old Dec 30, 2008 | 11:13 AM
Adam0331's Avatar
Adam0331
Any ideas on a good place to get one?
Old Dec 30, 2008 | 11:16 AM
megawatt00's Avatar
megawatt00
Get it checked out right away Adam, A bad alt can take out your batteries with it.
Old Dec 30, 2008 | 12:36 PM
Adam0331's Avatar
Adam0331
Ok, Jim will do, thanks. I'll take a look over everything tonight to see if there are any loose wires or anything.
Old Dec 30, 2008 | 12:42 PM
clintbonnie
Did you check your voltage while the engine was idling at the batteries? You should have about 14.3 volts.. If so, your alternator is probably working OK and it is maybe a wire shorting..
Old Dec 30, 2008 | 12:46 PM
Adam0331's Avatar
Adam0331
I don't have a voltimeter. I'll have to get my hands on one. Do you just touch it to the battery terminal?
Old Dec 30, 2008 | 02:34 PM
Ponyboychris
Yes, if it don't read around 14.1 to 14.3 volts with the GPR off, you may have and alternator going south. I got lucky with my truck, I do have an aftermarket voltmeter in my gauge pod and noticed while driving it was reading 11.5 volts. I looked at the dash and the light was flickering, then went steady after 20 minutes of driving.
Old Dec 31, 2008 | 08:14 AM
Adam0331's Avatar
Adam0331
Mine still hasn't gone steady it just flickers when I accelerate then when I let off it goes off. And it hasn't done it the past couple of days now. I can't figure it out. Maybe I have a short somewhere.
Old Dec 31, 2008 | 08:21 AM
F350-6's Avatar
F350-6
Check the voltage Adam. Last time I let my light come on and go off for a few days it ended up killing one of my batteries. If you ignore it, you'll end up needing a new alternator and new batteries.
Have you checked the connections at the batteries and the back of the alternator to make sure nothing is loose?
Old Dec 31, 2008 | 08:40 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
another option over a new one is if you have an alternator & starter shop nearby. i have a local guy who will rebuild your alternator for less than the cost of a new and up the wattage or voltage or w/e and give a lifetime warranty on all his stuff. never had one of his rebuilds fail me yet.....
Old Dec 31, 2008 | 09:10 AM
Adam0331's Avatar
Adam0331
Thanks for all the help guys. I just checked the battery and alternator connections, nothing looks wrong there. I'll have to get my hands on a voltimeter ASAP.
