Battery light flicker....
Old 11-11-2008, 07:00 PM
Futuresweets-10's Avatar
Futuresweets-10
Futuresweets-10 is offline
Futuresweets-10 is gaining momentum as a positive member of FTE.
A few days ago I was driving and the battery light came on for about 20 seconds then went back off. After staying off for about 10seconds it flickered two or three times. It hasnt come back on or flickered since. When it first came on I turned my head lights on and my radio up just to see if that would cause a problem and it didnt. The whole time the voltage gauge showed great voltage. Ideas?
Old 11-11-2008, 07:23 PM
just another truck's Avatar
just another truck
just another truck is offline
just another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputation
If you have time, do a search, there is another thread with the very same question, but be prepaired to replace you alterantor.. sorry man..
Old 11-11-2008, 07:25 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Your alternator is giving you a warning.
https://www.ford-trucks.com/forums/7...-then-off.html
Old 11-11-2008, 07:26 PM
zx250's Avatar
zx250
zx250 is offline
Of the next Riffraff East
zx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant future
It will probably show back up, then again sooner than before, each time faster than the last, then stay on until you batteries are dead and your lights are out. That is the way most alternators die.
Old 11-12-2008, 05:37 PM
Futuresweets-10
That other thread is actually what made me remember to post this..... His problem seemed to be a little bit different then mine so thats why I did a new thread. Thanks guys.
Old 11-13-2008, 11:46 AM
Winmilcook
Winmilcook is offline
Winmilcook is starting off with a positive reputation.
I'm haveing the same trouble with and early '99. I had the alternator rebuilt by a local shop that has done many jobs for me. The alternator checks out fine with output at factory specs 14.5 v. New motorcraft batteries. I wiggled the 2 wire connector on top of the alternator and the yellow wire will predictably cause the light to come on and off. Replaced the pigtail and sprayed the contacts with cleaner and it seems to have helped some. I still have the light come on but much less. I'm not sure where the wire goes, but I'm going to trace it out and bypass it to see if it fixes it. I'll let you know
Padlock
10-31-2014 08:56 PM
Steck804
1997 - 2003 F150
05-27-2014 10:07 AM
300sixnick
30
01-21-2014 11:06 AM
12valveEx
08-16-2013 08:24 PM
Ron Mantz
1999 to 2016 Super Duty
11-08-2012 09:30 PM
Quick Reply: Battery light flicker....
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
