Sponsored by: Innova
Sub Wiring Q's
Old Dec 29, 2008 | 08:19 AM
03_PSD's Avatar
03_PSD
Sub Wiring Q's
I'm about to build a bigger sub enclosure for my truck because I'm getting a 3rd solo-baric. Currently I have 2-8" L7 solo-barics to a 1200 watt phoenix gold xeon amp that is 1 ohm stable. What would be the best way to wire all three subs together parallel or in series? Also could you give or explain the wiring diagram?
Old Dec 29, 2008 | 12:47 PM
ReAX's Avatar
ReAX
1 ohm stable gives you a decent slack, however we need to know the resistance of the subs to get it right.
Assuming all are SVC 4ohm. All three in parallel (all positives to amp positive and all neg to amp neg), you should have a total load of 1.33ohm Which is above 1 ohm and the amp should be fine. This is going to be the lowest load. In series 3 SVC 4 ohm speakers would be 12ohm load on the amp. DVC also adds another hitch, so please provide voice coil and resistance.
Old Dec 29, 2008 | 01:11 PM
03_PSD's Avatar
03_PSD
sorry about that, they are all 4 ohm speakers
Old Dec 29, 2008 | 01:16 PM
ReAX's Avatar
ReAX
4 ohm SVC or DVC? I can draw up a quick diagram if you need it, put parallel means all positives are tied to the positive from the amp and all negatives are tied to the neg on the amp.
Old Dec 29, 2008 | 01:23 PM
03_PSD's Avatar
03_PSD
I'm guessing that DVC = Dual Voice Coil? They are DVC 4 ohm.
Old Dec 29, 2008 | 01:24 PM
03_PSD's Avatar
03_PSD
gotta ya on the parallel wiring
Old Dec 29, 2008 | 01:30 PM
crum71's Avatar
crum71
1/8 mile Oval Track
Rockford Fosgate® - Woofer WiringWizard
Hope this helps
Old Dec 29, 2008 | 01:33 PM
ReAX's Avatar
ReAX
Now DVC makes it different. DVC is going to be wired like 6 separate speakers. If you wire them all as parallel, you will have .66 ohm load and your 1 ohm stable amp will fail. Your going to have to get a little more indepth here and use series/parallel. Basically on each speaker you have 4 connectors (2 positive, 2 negative). You need to make a jumper to connect a positive and a negative on each one. Then use the free positive to connect to the amp positive and the neg to the amp neg. This will make each speaker 8ohm, and three in parallel would give you a load of 2.66ohm.
Old Dec 29, 2008 | 01:45 PM
03_PSD's Avatar
03_PSD
Great help ReAX and Scott!!
Old Dec 29, 2008 | 02:02 PM
ReAX's Avatar
ReAX
Option 1 draws out what I was trying to describe. So 1200 watt at 1 ohm. p=(e*e)/r, so 34.6v. At 2.67ohm, and you have 448.3 watts coming from the amp.
Old Jan 6, 2009 | 08:20 AM
03_PSD's Avatar
03_PSD
Thanks for the help guys, got the new box built and the subs wired correctly!!
WB4IUY
Aug 20, 2016 07:59 PM
tbax46
Oct 18, 2014 03:08 PM
Ford_Six
Garage & Workshop
Nov 18, 2011 10:47 PM
CruiserClass
Aug 2, 2007 07:28 PM
