Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Welding lathe
Old Nov 17, 2011 | 11:15 PM
Ford_Six's Avatar
Ford_Six
Welding lathe
The company I work for builds automated welding systems, and this is one of the biggest welding lathes they have built. This is also my first solo project, and it would be great if it wasn't the engineer's first solo project as well. Unfortunately, I've had to take this thing back down quite a ways to rework a few things, but I'm finally back to forward progress.
Those chucks are 25" capacity, the two bigger ones are both powered and are air operated, while the thinner one in the foreground is a manual operated idler.
Old Nov 18, 2011 | 01:10 AM
ford2go's Avatar
ford2go
Looks like fun stuff. Hope the engineer guy didn't have too many oopsies in the design.
hj
Old Nov 18, 2011 | 10:24 AM
muscletruck7379's Avatar
muscletruck7379
impressive. I have worked with automated sub-arcs that were used for welding tanks for the oilfield (maintenance crew). but they weren't quite this extreme. i take it this lathe is for heliarc welding?
Old Nov 18, 2011 | 10:47 PM
Ford_Six's Avatar
Ford_Six
hj
You have no idea. I have been running into walls all week that were problems I had mentioned two to three weeks ago but was brushed off with "That's the way we've always done it" meaning he looked at the plans for another system years back and saw this item.
This will actually be for plasma arc welding, which is similar to TIG but puts a lot more Joules per inch into the metal, and is a keyhole process (it basically blows a controlled hole through the material and refills it).
underthebridgejim
23
Oct 16, 2016 05:25 PM
Tim Young
Garage & Workshop
Sep 21, 2016 09:05 AM
preppypyro
20
Jul 8, 2011 09:17 PM
3Mike6
N. California Chapter
17
Aug 24, 2007 12:19 AM
cigarxtc
Garage & Workshop
May 3, 2004 05:18 PM
