Injector Question
Old Dec 28, 2008 | 08:12 PM
97 HD's Avatar
97 HD
Injector Question
Ive been snooping around on Rosewoods site. Let me ask yall something to see if I understand correctly. If I send in my injectors to have them rebuilt/modified there are no repair fees. Even though mine most likely have some stuff wrong with them. The repair fees only apply if I order a set of injectors, then send mine back as cores.
My Injectors in current condition +$500= is this correct?
Old Dec 28, 2008 | 08:25 PM
tjbeggs's Avatar
tjbeggs
No there will be extra fee's if you have hard parts that need to be replaced.
Old Dec 28, 2008 | 08:31 PM
c00nhunterjoe's Avatar
c00nhunterjoe
the only repair fee that is included is the nozzle springs. he replaces them no matter what the condition. but odds are that if you truck is running A OK and you are buying stage 1's just to have then you wont have any internal issues
Old Dec 28, 2008 | 08:51 PM
97 HD's Avatar
97 HD
mine is not running a ok. ive been putting off injectors for a while. back during the summer my mechanic told me i have one or more that may be leaking fuel into the cylinders. after my truck has been setting for a while, say overnight or while im at work, when i start the truck it will smoke gray/white smoke untill I get it all blown out. then i can detect a slight miss at idle and if I rev it will miss at about 2200 rpm. I went out to start the truck one day last week and it would not start. Truck would turn over a bit and stop. Hydrolock. I turned the engine over by hand a few times and then it started. I figured that pretty well confirmed a leaking injector. other than these issues truck runs ok. once i get all the stuff blown out at start up and get running down the highway its ok, maybe down on power a tad bit, but its hard to tell for sure. I did an oil change and no fuel in the oil, oil was thick and black.
Old Dec 28, 2008 | 09:01 PM
c00nhunterjoe
ouch, be careful with the hydro lock, its very easy to bend a rod. jim lists prices for replacement parts charges on the site.
Old Dec 28, 2008 | 09:03 PM
tjbeggs's Avatar
tjbeggs
Yeah hydrolocking is not good nor is the fuel that is getting into your oil. You need to get that fixed ASAP!
Old Dec 28, 2008 | 09:10 PM
c00nhunterjoe
he did say he was lucky enough to not have it getting into the oil.....yet. either way leaking injectors are not something you want to mess with!! get it fixed!
Old Dec 28, 2008 | 09:18 PM
97 HD's Avatar
97 HD
NO fuel in the oil, oil is ok. yeah I gotta figure out how I can do without my truck for a while so I can pull my injectors and send them in. Ive been working 7 days a week and I dont have a spare vehicle to drive.
Old Dec 28, 2008 | 09:19 PM
97 HD's Avatar
97 HD
what are my chances it could just be o-rings?
Old Dec 28, 2008 | 09:22 PM
tjbeggs's Avatar
tjbeggs
Unless he had his oil tested it would be nearly impossible to tell just by looking at it and I would find it nearly impossible to believe that fuel would not seep by the rings.
Old Dec 28, 2008 | 09:30 PM
97 HD's Avatar
97 HD
I agree. The point i was trying to make was the oil level on the stick was ok not over full, and the oil was thick, not thined down with fuel. There could be traces of fuel getting into the oil.
Do you all think that based on what I described above with the hydrolock and smoke that my problem is in the injectors or are ther other possibilities to look at.
Old Dec 28, 2008 | 09:33 PM
c00nhunterjoe
it is most likely one injector with an internal failure. exteranal o-ring failures wouldnt normally cause the concern unless the compression ring failed and took the other o-rings out completly as well. but if that happened then you'd have major misfires and stalls accompanied by a no-start when it hits the oil ring
Old Dec 29, 2008 | 06:54 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I'm not really trying to be a salesman here, honest!
But injectors need attention like many other mechanical parts to the motor. It could just be orings, but I doubt it. 200k miles seems to be the normal point for overhauling at least.The older trucks are at a huge disadvantage for wear because their Plunger & Barrels are not Tungsten coated. The coating, available on all injectors (and replacement P&B's) since '99.5 are much more durable. Many of the older trucks with higher mileage need 1 or 2 or more P&B's replaced, whereas I've only had one set of '99.5 and up injectors need new P&B's. So there is value there for your money there when you purchase new P&B's.
Also, nozzles are another area of concern. Nozzle condition is near impossible to determine without expensive nozzle flow equipment, and you're really just as well to replace the nozzles on high mileage injectors. I see it everyday on the flow bench, used nozzles do not flow as much as new nozzles.
Let me know if you have any questions.
Thanks,
Jim
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Dec 29, 2008 | 12:14 PM
97 HD's Avatar
97 HD
Thanks Jim.
I will probably be giving you a call soon.
zeppelingto
Apr 7, 2012 09:06 PM
4x4countryboy
Mar 26, 2012 07:14 PM
IHMANKY
Oct 19, 2011 10:28 PM
BradyCouchman
S. California Chapter
Jul 19, 2008 11:17 PM
coldnorthpole
Mar 3, 2007 07:19 AM
