02 7.3 with big problems help please
Old Dec 28, 2008 | 08:17 PM
cadetcommander20's Avatar
cadetcommander20
i done that a little while back and it was like 375 psi to 400 psi how much should it have
Old Dec 28, 2008 | 08:18 PM
cadetcommander20
i heard a while back that it was 700 psi but is that with or with out boost from the turbo
Old Dec 28, 2008 | 08:30 PM
zx250's Avatar
zx250
Of the next Riffraff East
Main thing is if all eight cyl. were near the same. Have you checked you injectors? You could have a bad one or two.
Old Dec 28, 2008 | 08:35 PM
cadetcommander20
just check them with a computer right
Old Dec 28, 2008 | 08:40 PM
F350-6's Avatar
F350-6
Some oil in your intake or IC tubes is normal.
Blue or blue/white smoke:
Caused by insufficient fuel or oil consumption. Normal when engine is cold or idling for extended periods.
Excessive smoke could be caused by air in the fuel, contaminated fuel, loose or plugged injectors, worn or leaking injector o-rings, thermostat stuck open, oil consumption, or plugged crankcase depression regulator valve. Also PCM inputs such as MAP or ICP sensors.
I would think injector O-rings would be a possibility. Do you know anyone with a good scanner that can to a CCT or monitor change in rotational velocity % for you? How much oil are you using? Any signs of oil in the bottom of the fuel filter bowl?
Old Dec 28, 2008 | 08:51 PM
cadetcommander20
there is no oil in the fuel filter bowl and it is not using enough oil between changes to have to add any but it poors white smoke with a blueish tint when the truck idles all the time would a good injector cleaner help if it is a plugged injector and what is a good cleaner dont think it is themostat because truck warms up fine where is the crankcase depression regulator valve located and how can i check or repair it
Old Dec 28, 2008 | 09:04 PM
F350-6's Avatar
F350-6
I'd check the hose on the MAP to be on the safe side, also make sure your air filter is in good shape. Does your engine sound louder than other 7.3's? There was a guy here a few days ago that found an injector bolt that was almost 2 full turns loose. Loose injectors will make your truck sound louder (but not enough for you to notice since it happens gradually).
Old Dec 28, 2008 | 09:10 PM
cadetcommander20
i checked one side will check the other side later this week what is the MAP and where is it at the air filter is in good shape also where is the crankcase depression regulator at is it on top of the drivers side valve cover
jp1gt
Jan 25, 2011 04:42 PM
turtletalk
63
Dec 27, 2009 02:58 AM
Phillip1959
22
May 21, 2009 07:15 AM
cadetcommander20
21
Dec 31, 2008 08:58 PM
FireMarshal3311
May 14, 2004 07:06 AM
